xfcvi.qlgc events
xfcvi.qlgc.async.event.overflow
- Severity
ERROR
 - Description
This message occurs when total number of async events are overflowed.
 - Corrective Action
(None).
 - Syslog Message
FC-VI adapter: Port %s async event overflowed. Resetting the adapter.
 - Parameters
port (STRING): xfcvi Interconnect NIC.
xfcvi.qlgc.connErr
- Severity
ERROR
 - Description
This message occurs when the FC-VI adapter detects a connection error. The FC-VI driver will attempt to retry the connection.
 - Corrective Action
If this message repeats frequently, there may be an issue with the FC fabric or the adapter. Contact NetApp technical support.
 - Syslog Message
FC-VI adapter: Port %s detects connection error. FC-VI opcode = %s(0x%x), QP name = %s, QP index = %d, Remote node's system id = %llu. %s
 - Parameters
port (STRING): Interconnect NIC.
opcode_str (STRING): xfcvi opcode.
opcode (INTHEX): xfcvi opcode.
qpname (STRING): QP name.
qpnum (INT): QP number.
systemID (LONGINT): Remote node's system ID.
info (STRING): Additional info.
xfcvi.qlgc.cpr.reset.cancelled
- Severity
ERROR
 - Description
This message occurs when the CPR reset initiated by the FC-VI port got cancelled.
 - Corrective Action
Reboot the filer. If issue still persists then replace the xfcvi adapter.
 - Syslog Message
FC-VI adapter: CPR reset initiated by port %s got cancelled. Offlining the port.
 - Parameters
port (STRING): xfcvi Interconnect adapter.
xfcvi.qlgc.cpr.reset.failed
- Severity
ERROR
 - Description
This message occurs when the CPR reset initiated by the FC-VI port fails.
 - Corrective Action
 - Syslog Message
FC-VI adapter: CPR reset initiated by port %s failed.
 - Parameters
xfcvi.qlgc.cpr.reset.unsupported
- Severity
ERROR
 - Description
This message occurs when the CPR reset is not supported by the adapter.
 - Corrective Action
 - Syslog Message
FC-VI adapter: CPR reset is not supported by port %s.
 - Parameters
xfcvi.qlgc.FrameDiscardErr
- Severity
ERROR
 - Description
This message occurs when the FC-VI adapter firmware discards a received frame because of a receive frame error.
 - Corrective Action
(None).
 - Syslog Message
FC-VI adapter: Discarded a received frame because of a receive frame error. Port %s, QP name = %s, QP index = %d, exchange ID 0x%x, address offset 0x%x, remote node's system id = %llu. %s
 - Parameters
qp_name (STRING): QP name.
qp_index (INT): QP number.
exchange_id (INTHEX): Exchange ID.
address (INTHEX): Address offset of the last good frame.
system_id (LONGINT): Remote node's system id.
xfcvi.qlgc.hard.reset.failed
- Severity
ERROR
 - Description
This message occurs when an FC-VI port's soft reset fails.
 - Corrective Action
If CPR reset is not supported in the platform, then reboot the filer to recover from this issue. If issue persists then replace the xfcvi adapter.
 - Syslog Message
FC-VI adapter: Hard reset failed at port %s.
 - Parameters
xfcvi.qlgc.invalid.data
- Severity
ERROR
 - Description
This message occurs when xfcvi driver receives invalid data from firmware.
 - Corrective Action
(None).
 - Syslog Message
FC-VI adapter: Port %s received invalid data. QP index = %d, completion status = %s(status code = %d), opcode = %s(%d), remote node's system id = %llu. %s
 - Parameters
qpnum (INT): QP index.
status (STRING): Completion status.
status_code (INT): Completion status code.
opcode_str (STRING): xfcvi opcode in string.
opcode (INT): xfcvi opcode.
systemID (LONGINT): Remote node's system Id.
xfcvi.qlgc.invalid.exch.address
- Severity
ERROR
 - Description
This message occurs when xfcvi driver receives a response with invalid exchange address.
 - Corrective Action
(None).
 - Syslog Message
FC-VI adapter: Port %s received invalid exchange address for %s. QP name = %s, QP index = %d, expected exchange address = 0x%x, received exchange address = 0x%x. %s
 - Parameters
resp_type (STRING): Response type.
exp_oxid (INTHEX): Expected exchange address.
rcvd_oxid (INTHEX): Received exchange address.
xfcvi.qlgc.invalid.qp
- Severity
ERROR
 - Description
This message occurs when xfcvi driver receives invalid QP index from firmware.
 - Corrective Action
(None).
 - Syslog Message
FC-VI adapter: Port %s received invalid QP. Received QP index = %d, completion status = %s(status code = %d), entry type = %s(entry code = %d). %s
 - Parameters
entry_type (STRING): Request/Response entry type.
entry_code (INT): Request/Response entry code.
xfcvi.qlgc.invalid.response
- Severity
ERROR
 - Description
This message occurs when xfcvi driver receives invalid response from firmware.
 - Corrective Action
(None).
 - Syslog Message
FC-VI adapter: Port %s received invalid response. %s. %s
 - Parameters
error_type (STRING): Type of error.
xfcvi.qlgc.ioErr
- Severity
ERROR
 - Description
This message occurs when the FC-VI driver receives some IO error.
 - Corrective Action
No corrective action is required. The driver internally resets the adapter if required. However, if you see this message frequently, there might be an issue with the FC fabric or the adapter. Contact NetApp technical support.
 - Syslog Message
FC-VI adapter: xfcvi driver on port %s received IO error. Status = %s(status code = 0x%x), xfcvi opcode = %s(0x%x), QP name = %s, QP index = %d, Remote node's system id = %llu.
 - Parameters
status_str (STRING): Completion status in string.
status (INTHEX): Completion status code.
qpName (STRING): QP name.
qpIndex (INT): QP number.
xfcvi.qlgc.login.timedout
- Severity
NOTICE
 - Description
This message occurs when port login request times out.
 - Corrective Action
(None).
 - Syslog Message
FC-VI adapter: Remote port login timedout on port %s. Remote port id = 0x%x, Remote port handle = %d. %s
 - Parameters
portid (INTHEX): Remote port identifier.
porthandle (INT): Remote port handle.
xfcvi.qlgc.ls.reject
- Severity
ERROR
 - Description
This message occurs when the xfcvi firmware rejects a link service.
 - Corrective Action
(None).
 - Syslog Message
FC-VI adapter: Link service = %s(code = %d), rejected on port %s. %s
 - Parameters
ls (STRING): Link service name.
ls_code (INT): Link service code.
xfcvi.qlgc.mbox.cmd.pending
- Severity
ERROR
 - Description
This message occurs when a mailbox command is pending for a long time.
 - Corrective Action
(None).
 - Syslog Message
FC-VI adapter: Mailbox command '%s(code = 0x%x)' pending on port %s. %s
 - Parameters
cmd (STRING): Mailbox command.
cmd_code (INTHEX): Mailbox command code.
xfcvi.qlgc.mbox.cmd.timedout
- Severity
ERROR
 - Description
This message occurs when a mailbox command times out.
 - Corrective Action
(None).
 - Syslog Message
FC-VI adapter: Mailbox command '%s(code = 0x%x)' timedout on port %s. %s
 - Parameters
xfcvi.qlgc.no.iu.buffer
- Severity
ERROR
 - Description
This message occurs when the xfcvi firmware identifies no more incoming IU buffers in the free pool.
 - Corrective Action
(None).
 - Syslog Message
FC-VI adapter: Port %s doesn't have free IU buffer. %s
 - Parameters
xfcvi.qlgc.no.recv.buffer
- Severity
ERROR
 - Description
This message occurs when the xfcvi firmware identifies no more receive buffers available for the incoming receive frames.
 - Corrective Action
(None).
 - Syslog Message
FC-VI adapter: Port %s doesn't have free receive buffer. QP name = %s, QP index = %d, Message ID = 0x%x. %s
 - Parameters
msg_id (INTHEX): Message id of the incoming message.
xfcvi.qlgc.oodErr
- Severity
ERROR
 - Description
This message occurs when the FC-VI driver receives out of order completions.
 - Corrective Action
 - Syslog Message
FC-VI adapter: xfcvi driver on port %s receives out of order completions. xfcvi opcode = %s(0x%x), QP name = %s, QP index = %d, Remote node's system id = %llu.
 - Parameters
xfcvi.qlgc.PCIErr
- Severity
ERROR
 - Description
This message occurs when the FC-VI adapter firmware encounters a PCI error because it cannot write a frame to host memory.
 - Corrective Action
(None).
 - Syslog Message
FC-VI adapter: PCI error while writing a frame to host memory. Port %s, QP name = %s, QP index = %d, exchange ID 0x%x, address offset 0x%x, remote node's system id = %llu. %s
 - Parameters
xfcvi.qlgc.port.reset
- Severity
ERROR
 - Description
This message occurs when a xfcvi port resets.
 - Corrective Action
(None).
 - Syslog Message
FC-VI adapter: Resetting the port %s. %s
 - Parameters
reason (STRING): Reason for port reset.
xfcvi.qlgc.qp.create.err
- Severity
ERROR
 - Description
This message occurs when QP creation fails.
 - Corrective Action
(None).
 - Syslog Message
FC-VI adapter: Failed to create QP on port %s. Requested QP index = %d, completion status = %s(status code = %d). %s
 - Parameters
xfcvi.qlgc.qp.destroy.failed
- Severity
ERROR
 - Description
This message occurs when the QP destroy request failed.
 - Corrective Action
(None).
 - Syslog Message
FC-VI adapter: QP destroy failed on port %s. QP index = %d. %s
 - Parameters
xfcvi.qlgc.qpErr
- Severity
ERROR
 - Description
This message occurs when the FC-VI driver receives a QP error from the Firmware. The FC-VI driver will attempt to retry the connection.
 - Corrective Action
 - Syslog Message
FC-VI adapter: xfcvi driver on port %s received QP Error. QP name = %s, QP index = 0x%x, VI state = %s(state code = 0x%x), sub-error = %s(error code = 0x%x). Remote node's system id = %llu. This error has occurred %d times. %s
 - Parameters
port (STRING): Interconnect Adapter.
qpnum (INTHEX): QP number.
state_str (STRING): QP state.
state (INTHEX): QP state code.
suberror (STRING): Sub-error.
code (INTHEX): Sub-error code.
system_id (LONGINT): Remote node's system ID.
errcnt (INT): Number of times QP async error was encountered.
xfcvi.qlgc.rcvd.invalid.iu.buffer
- Severity
ERROR
 - Description
This message occurs when the FC-VI adapter receives invalid information unit buffer.
 - Corrective Action
 - Syslog Message
FC-VI adapter: Port %s received invalid IU buffer. Status = %s(status code = 0x%x), xfcvi opcode = %s(0x%x), QP name = %s, QP index = %d, buffer handle = %d, Remote node's system id = %llu. %s
 - Parameters
bufhdl (INT): Buffer handle.
xfcvi.qlgc.receive.error
- Severity
ERROR
 - Description
This message occurs when the xfcvi firmware detects an error in the received frame.
 - Corrective Action
(None).
 - Syslog Message
FC-VI adapter: Received bad frame on port %s. Mailbox-1 = %d, Mailbox-2 = %d. %s
 - Parameters
mbox1 (INT): Content of mailbox-1.
mbox2 (INT): Content of mailbox-2.
xfcvi.qlgc.received.disconnect
- Severity
NOTICE
 - Description
This message occurs when xfcvi driver receives disconnect request from partner.
 - Corrective Action
(None).
 - Syslog Message
FC-VI adapter: Disconnect request received on port %s. QP name = %s, QP index = %d, Remote node's system id = %llu. %s
 - Parameters
xfcvi.qlgc.received.reject
- Severity
NOTICE
 - Description
This message occurs when xfcvi driver receives connection reject from partner.
 - Corrective Action
(None).
 - Syslog Message
FC-VI adapter: Connect request rejected on port %s. QP name = %s, QP index = %d, Remote node's system id = %llu. %s
 - Parameters
xfcvi.qlgc.recvIUErr
- Severity
ERROR
 - Description
This message occurs when the FC-VI adapter receives some error in received information unit.
 - Corrective Action
 - Syslog Message
FC-VI adapter: Port %s received IU error. Status = %s(status code = 0x%x), xfcvi opcode = %s(0x%x), QP name = %s, QP index = %d, buffer handle = %d, Remote node's system id = %llu.
 - Parameters
xfcvi.qlgc.regDumped
- Severity
NOTICE
 - Description
This message occurs when the xfcvi driver saves a diagnostic dump in a file.
 - Corrective Action
(None).
 - Syslog Message
FC-VI adapter: Diagnostic dump for port %s saved to file %s.
 - Parameters
filename (STRING): File to which the diagnostic dump was saved.
xfcvi.qlgc.RespFrameErr
- Severity
ERROR
 - Description
This message occurs when the adapter firmware sends a response frame with the error bit set.
 - Corrective Action
(None).
 - Syslog Message
FC-VI adapter: Firmware sent a response with the error bit set. Port %s, QP name = %s, QP index = %d, exchange ID 0x%x, address offset 0x%x, remote node's system id = %llu. %s
 - Parameters
xfcvi.qlgc.risc.paused
- Severity
ERROR
 - Description
This message occurs when xfcvi RISC is paused.
 - Corrective Action
(None).
 - Syslog Message
FC-VI adapter: Port %s detected a RISC pause error. %s
 - Parameters
xfcvi.qlgc.rmt.link.down
- Severity
NOTICE
 - Description
This message occurs when xfcvi driver lost link to partner port.
 - Corrective Action
(None).
 - Syslog Message
FC-VI adapter: Link to partner node over port %s is down. Partner port id = 0x%x, partner node's system id = %llu. %s
 - Parameters
port_id (INTHEX): Partner port id.
system_id (LONGINT): Partner node's system id.
xfcvi.qlgc.rmt.link.up
- Severity
NOTICE
 - Description
This message occurs when xfcvi driver gets link to partner port.
 - Corrective Action
(None).
 - Syslog Message
FC-VI adapter: Link to partner node over port %s is up. Partner port id = 0x%x, partner node's system id = %llu. %s
 - Parameters
xfcvi.qlgc.sendIUError
- Severity
ERROR
 - Description
This message occurs when the FC-VI adapter fails to send an information unit.
 - Corrective Action
No corrective action is required. The driver internally retries. However, if you see this message frequently, there might be an issue with the FC fabric or the adapter. Contact NetApp technical support.
 - Syslog Message
FC-VI adapter: Port %s sendIU status = %s(status code = 0x%x), xfcvi opcode = %s(0x%x), QP name = %s, QP index = %d, Remote node's system id = %llu. %s
 - Parameters
status (INTHEX): Completion status code in hex.
opcode (INTHEX): xfcvi opcode in hex.
systemID (LONGINT): Remote node's system id.
xfcvi.qlgc.sent.disconnect
- Severity
NOTICE
 - Description
This message occurs when xfcvi driver sends disconnect request to remote partner.
 - Corrective Action
(None).
 - Syslog Message
FC-VI adapter: Disconnect request sent on port %s. QP name = %s, QP index = %d, Remote node's system id = %llu. %s
 - Parameters
xfcvi.qlgc.soft.reset.failed
- Severity
ERROR
 - Description
 - Corrective Action
None.
 - Syslog Message
FC-VI adapter: Soft reset failed at port %s.
 - Parameters
xfcvi.qlgc.system.error
- Severity
ERROR
 - Description
This message occurs when xfcvi driver receives system error from xfcvi firmware.
 - Corrective Action
No corrective action is required. The driver internally resets the adapter. However, if you see this message frequently, there might be an issue with the adapter/firmware. Contact NetApp technical support.
 - Syslog Message
FC-VI adapter: System Error on port %s. %s
 - Parameters
xfcvi.qlgc.TimeOutErr
- Severity
ERROR
 - Description
This message occurs when the adapter firmware cannot send a request.
 - Corrective Action
(None).
 - Syslog Message
FC-VI adapter: Firmware could not send a request. Port %s, QP name = %s, QP index = %d, exchange ID 0x%x, address offset 0x%x, remote node's system id = %llu. %s
 - Parameters
xfcvi.qlgc.transfer.error
- Severity
ERROR
 - Description
This message occurs when the xfcvi firmware detects a transfer error.
 - Corrective Action
(None).
 - Syslog Message
FC-VI adapter: %s transfer error on port %s. Affected queue number = %d. %s
 - Parameters
trans_type (STRING): Transfer type.
queue_num (INT): Queue number.
