block.giveback events
block.giveback.during.aufo
- Severity
ALERT
- Description
This message occurs during a storage failover (SFO) aggregate giveback, when a SnapMirror® active sync automatic unplanned failover operation is in progress.
- Corrective Action
Wait for the operation to finish. If giveback is required immediately, use the "override-veto true" parameter with the giveback command, or retry the operation with the "override-vetoes true" parameter. Note: Using this option might cause an I/O disruption.
- Syslog Message
Storage Failover giveback cannot complete for aggregate "%s" because an SnapMirror® active sync automatic unplanned failover is in progress.
- Parameters
aggrname (STRING): Name of the aggregate.
