ONTAP EMS reference
callhome.ch events
callhome.ch.ps.degraded
Severity
ERROR
This message occurs when a degraded chassis power supply unit (PSU) state exists. If your system is configured to do so, it generates and transmits an AutoSupport (or 'call home') message to NetApp technical support and to the configured destinations. Successful delivery of an AutoSupport message significantly improves problem determination and resolution.
Corrective Action
You might need to replace a chassis PSU. If you need assistance, contact NetApp technical support.
Syslog Message
Call home for %s
subject (STRING): AutoSupport subject or title for this event.
callhome.ch.ps.fan.bad.xmin
Severity
EMERGENCY
This message occurs when a power supply fan has been detected as no longer working and the overheating is expected shortly. If your system is configured to do so, it generates and transmits an AutoSupport (or 'call home') message to NetApp technical support and to the configured destinations. Successful delivery of an AutoSupport message significantly improves problem determination and resolution.
Corrective Action
Replace the power supply unit or the power supply unit's fan. If you need assistance, contact NetApp technical support.
Syslog Message
Call home for %s
callhome.ch.ps.fault
Severity
ERROR
This message occurs when one chassis power supply unit (PSU) fails. If your system is configured to do so, it generates and transmits an AutoSupport (or 'call home') message to NetApp technical support and to the configured destinations. Successful delivery of an AutoSupport message significantly improves problem determination and resolution.
Corrective Action
Syslog Message
Call home for %s
callhome.ch.ps.wrong.in
Severity
ERROR
This message occurs when a power supply is not connected to the correct type of power source (voltage, amperage, type, etc. difference). If your system is configured to do so, it generates and transmits an AutoSupport (or 'call home') message to NetApp technical support and to the configured destinations. Successful delivery of an AutoSupport message significantly improves problem determination and resolution.
Corrective Action
Connect the power supply to the proper power source or replace the power supply with the appropriate one for the available power source. If you need assistance, contact NetApp technical support.
Syslog Message
Call home for %s
