ONTAP EMS reference
cloud.creds events
cloud.creds.metadataConnFail
Severity
ERROR
This message occurs when the system cannot establish a communication link with the cloud provider's metadata server, in order to acquire the necessary temporary credentials used in signing API requests to the cloud object store server.
Corrective Action
Log in to the cloud provider's management console to examine the current set of running instances. Find the instance pertaining to this deployment of Cloud Volumes ONTAP® deployment, and then check its health from the console.
Syslog Message
ONTAP cannot communicate with the cloud provider's metadata server needed to acquire the temporary credentials used to access an object store server. Command: %s Error returned: %s Node: %s
command (STRING): Command used to contact the metadata server.
error (STRING): Error text received as response to the metadata server command.
nodeUuid (STRING): UUID of the node.
cloud.creds.notFound
Severity
ERROR
This message occurs when the system cannot acquire the temporary credentials from the cloud provider's metadata server that are necessary for signing API requests to the object storage server.
Corrective Action
Log in to the management console of the cloud provider to examine the current set of running instances. Find and check the health of the instance pertaining to this Cloud Volumes ONTAP deployment. Also verify that the role associated with the instance exists and grants the proper privileges.
Syslog Message
ONTAP cannot acquire credentials associated with the instance named '%s' on the metadata server. Node %s.
role (STRING): Name of the AWS IAM role or GCP Service Account or Azure Managed Service Identity associated with this Cloud Volumes ONTAP® instance.
cloud.creds.notInitialized
Severity
NOTICE
This message occurs when the system attempts to access credentials before initialization is complete.
Corrective Action
(None).
Syslog Message
Module on node %s attempted to access credential information before initialization was complete
