ONTAP EMS reference
cloud.dbtablenotfound events
cloud.dbtablenotfound EMS events occur when a cloud database table is not found in this cloud database service.
cloud.DBTableNotFound
Severity
ERROR
This message occurs when a cloud database table is not found in this cloud database service.
Corrective Action
Verify that the cloud database endpoint and table are valid. Once the issue is addressed, take over and give back the node.
Syslog Message
Cloud database endpoint "%s" and/or table "%s" are not valid for this ONTAP Cloud instance.
db_endpoint (STRING): Name of the cloud database endpoint associated with this ONTAP Cloud instance.
db_table (STRING): Name of the cloud database table associated with this ONTAP Cloud instance.
