ONTAP EMS reference
disk.encrypt events
disk.encrypt EMS events occur when ONTAP encounters issues associated with disk encryption operations.
disk.encrypt.destroy.complete
Severity
INFORMATIONAL
This message occurs when the disk encrypt destroy operation is completed.
Corrective Action
(None).
Syslog Message
Disk %s [S/N %s] has completed encrypt destroy.
diskName (STRING): Name of the device.
serialno (STRING): Serial number of the device.
disk.encrypt.range.check
Severity
ERROR
This message occurs when ONTAP® software detects that the reported capacity of an encrypting drive is different from the protected range capacity of the drive.
Corrective Action
Contact NetApp technical support.
Syslog Message
Drive %s["%s"] - The protected range capacity (%llu) of this encrypting drive is different from its reported capacity (%llu).
diskName (STRING): Name of the disk.
productID (STRING): Product name of the disk.
advertisedDriveCapacity (LONGINT): Capacity reported by the drive(in bytes).
protectedDriveCapacity (LONGINT): Protected capacity of the drive(in bytes), specifically the drive capacity that is protected using an authentication key.
disk.encrypt.revert.complete
Severity
NOTICE
This message occurs when the disk encrypt revert operation is completed.
Corrective Action
(None).
Syslog Message
Disk %s [S/N %s] has completed encrypt revert.
