ONTAP EMS reference
disk.fli events
disk.fli.abort.ioSent
Severity
NOTICE
This message occurs when an I/O operation below the SCSI layer is aborted because a Foreign LUN Import (FLI) abort message was issued.
Corrective Action
(None).
Syslog Message
An I/O with the opcode %s has been aborted on disk %s.
opcode (STRING): Opcode that specifies the operation that was aborted.
diskName (STRING): Name of the disk.
disk.fli.abort.ioUnSent
Severity
NOTICE
This message occurs when an I/O operation in the disk class layer is aborted because a Foreign LUN Import (FLI) abort message was issued.
Corrective Action
(None).
Syslog Message
An I/O with the block count %llu starting at offset %llu has been aborted on disk %s.
blockCount (LONGINT): Number of blocks that this I/O operation spans.
offset (LONGINT): Start of the I/O operation.
disk.fli.tmf.complete
Severity
NOTICE
This message occurs when a Foreign LUN Import (FLI) message (abort or LUN reset) is completed.
Corrective Action
(None).
Syslog Message
Foreign LUN Import (FLI) message: %s completed on disk %s with status %d.
msgType (STRING): Specifies which type of FLI message: either abort or LUN reset.
diskName (STRING): Name of the disk to which this FLI message was sent.
returnStatus (INT): Completion status of the FLI message.
