ONTAP EMS reference
disk.partition events
disk.partition.exceeded
Severity
ERROR
This message occurs when the disk partition layout contains more partitions than are supported by the system.
Corrective Action
Fix the unsupported disk partition layout by using the 'disk unpartition' command to make the disk a spare disk.
Syslog Message
Disk %s has %d partitions, which exceeds the maximum of %d partitions.
disk_name (STRING): Name of the disk.
partition_count (INT): Number of partitions on the disk.
max_partition_count (INT): Maximum number of partitions supported per disk.
