extcache.rw events
extcache.rw EMS events occur when ONTAP encounters issues associated with external cache resource allocation and cache warming operations.
extCache.rw.alloc
- Severity
NOTICE
- Description
This message occurs when an external cache cannot obtain sufficient system resources. This causes the external cache component to be unable to rewarm after a reboot, which might cause a temporary performance impact.
- Corrective Action
(None).
- Syslog Message
WAFL external cache could not allocate resources: %s.
- Parameters
description (STRING): String identifying the specific resources that were not obtained.
extCache.rw.canceled
- Severity
NOTICE
- Description
This message occurs when the external cache cannot complete cache rewarming. This causes the external cache component to start with no data cached, which might cause a temporary performance impact.
- Corrective Action
(None).
- Syslog Message
WAFL external cache reconstruct was canceled.
- Parameters
(None).
extCache.rw.configChange
- Severity
INFORMATIONAL
- Description
This message occurs when the external cache warming logic detects a change in cache hardware configuration. This causes the external cache component to start with no data cached for any aggregates, which can cause a temporary performance impact. The problem should resolve itself at the next reboot.
- Corrective Action
(None).
- Syslog Message
WAFL external cache warming aborted due to hardware configuration change.
- Parameters
(None).
extCache.rw.emptyCache
- Severity
INFORMATIONAL
- Description
This message occurs when the external cache warming process terminates due to a lack of active cache entries.
- Corrective Action
(None).
- Syslog Message
WAFL external cache warming canceled: cache is not in use.
- Parameters
(None).
extCache.rw.entry
- Severity
NOTICE
- Description
This message occurs when the external cache cannot rebuild cache entries from stored data. This event is caused by an internal error and results in a small portion of the cache remaining empty during rewarming.
- Corrective Action
(None).
- Syslog Message
WAFL external cache experienced an internal error during reconstruct.
- Parameters
(None).
extCache.rw.headerInvalid
- Severity
NOTICE
- Description
This message occurs when the external cache warming process encounters an invalid file header. This causes the external cache component to start with no data cached for one or all aggregates, which might cause a temporary performance impact.
- Corrective Action
(None).
- Syslog Message
WAFL external cache warming encountered an invalid file header: %s.
- Parameters
section (STRING): String identifying the header section in question.
extCache.rw.io.readLimit
- Severity
NOTICE
- Description
This message occurs when the external cache exceeds the allowable threshold for I/O errors on reads. This causes the external cache component to start with no data cached for any aggregates and might result in temporarily degraded performance.
- Corrective Action
(None).
- Syslog Message
WAFL external cache warming encountered too many read errors: %s (%d).
- Parameters
description (STRING): String providing information about the operation.
number (INT): Number of unsuccessful reads detected.
extCache.rw.io.write
- Severity
INFORMATIONAL
- Description
This message occurs when the external cache detects an I/O error on a write. This causes the external cache component to be unable to reconstruct portions of the cache and might result in slightly degraded performance.
- Corrective Action
(None).
- Syslog Message
WAFL external cache I/O write: %s, code %d.
- Parameters
detail (INT): Detailed error code about the operation.
extCache.rw.io.writeLimit
- Severity
NOTICE
- Description
This message occurs when the external cache exceeds the allowable threshold for I/O errors on writes. This causes the external cache component to start with no cached data for any aggregates and might result in temporarily degraded performance.
- Corrective Action
(None).
- Syslog Message
WAFL external cache warming encountered too many write errors: %s (%d).
- Parameters
number (INT): Number of unsuccessful writes detected.
extCache.rw.log.bufLoad
- Severity
NOTICE
- Description
This message occurs when the external cache invalidation log cannot load a WAFL® buffer. This causes the external cache component to be unable to rewarm the aggregate in question after a reboot, which might cause a temporary performance impact.
- Corrective Action
(None).
- Syslog Message
WAFL external cache invalidation log buf could not be loaded: aggregate %s.
- Parameters
aggregate (STRING): String identifying the aggregate that experienced the problem.
extCache.rw.log.disabled
- Severity
NOTICE
- Description
This message occurs when external cache invalidation logging is disabled for an aggregate. This causes the external cache component to be unable to rewarm that aggregate after a reboot, which might cause a temporary performance impact.
- Corrective Action
(None).
- Syslog Message
WAFL external cache invalidation log disabled: aggregate %s: %s.
- Parameters
reason (STRING): String indicating the cause of the problem.
extCache.rw.log.freeSpace
- Severity
NOTICE
- Description
This message occurs when an external cache log file cannot be written due to lack of free space. This causes the external cache component to be unable to rewarm a specific aggregate or the entire cache after a reboot, which might cause a temporary performance impact.
- Corrective Action
Make sufficient space available on the aggregate.
- Syslog Message
WAFL external cache log out of space on aggregate %s (needs %d bytes).
- Parameters
aggregate (STRING): String identifying the aggregate that experienced the failure.
bytes (INT): Number of free bytes needed to successfully open the log file.
extCache.rw.log.maxSize
- Severity
NOTICE
- Description
This message occurs when an external cache log file reaches its maximum size. This causes the external cache component to be unable to rewarm a specific aggregate or the entire cache after a reboot, which might cause a temporary performance impact.
- Corrective Action
(None).
- Syslog Message
WAFL external cache log reached maximum size: aggregate %s, log %s.
- Parameters
logtype (STRING): String identifying the log file that reached the maximum size.
extCache.rw.log.open
- Severity
NOTICE
- Description
This message occurs when the external cache cannot open a log file. This causes the external cache component to be unable to rewarm some or all of the cached aggregates after a reboot, which might cause a temporary performance impact.
- Corrective Action
(None).
- Syslog Message
WAFL external cache log could not be opened: aggregate %s, log %s.
- Parameters
logtype (STRING): String identifying the type of log file that could not be opened.
extCache.rw.log.range
- Severity
NOTICE
- Description
This message occurs when the external cache invalidation log has a block address that is not within an aggregate's address range. This causes the external cache component to be unable to rewarm the aggregate in question after a reboot, which might cause a temporary performance impact.
- Corrective Action
(None).
- Syslog Message
WAFL external cache invalidation log block out of range: aggregate %s block %lld.
- Parameters
block (LONGINT): Block encountered in the invalidation log.
extCache.rw.log.read
- Severity
NOTICE
- Description
This message occurs when the external cache cannot read from a log file. This causes the external cache component to be unable to rewarm some or all of the cached aggregates during a reboot, which might cause a temporary performance impact.
- Corrective Action
(None).
- Syslog Message
WAFL external cache log could not be read: aggregate %s, log %s.
- Parameters
logtype (STRING): String identifying the log file that could not be read.
extCache.rw.log.seek
- Severity
NOTICE
- Description
This message occurs when the external cache cannot manipulate a log file. This causes the external cache component to be unable to rewarm after a reboot, which might cause a temporary performance impact.
- Corrective Action
(None).
- Syslog Message
- Parameters
extCache.rw.log.write
- Severity
NOTICE
- Description
This message occurs when the external cache cannot write to a log file. This causes the external cache component to be unable to rewarm some or all of the cached aggregates after a reboot, which might cause a temporary performance impact.
- Corrective Action
(None).
- Syslog Message
WAFL external cache log could not be written: aggregate %s, log %s.
- Parameters
logtype (STRING): String identifying the log file that could not be written.
extCache.rw.replay.canceled
- Severity
NOTICE
- Description
This message occurs when the external cache cannot successfully process the invalidation logs for an individual aggregate. This causes the external cache component to start with no data cached for the aggregate, which might cause a temporary performance impact.
- Corrective Action
(None).
- Syslog Message
WAFL external cache replay canceled for aggregate %s: %s.
- Parameters
aggregate (STRING): String identifying the aggregate in question.
extCache.rw.replay.complete
- Severity
INFORMATIONAL
- Description
This message occurs when the external cache finishes processing the invalidation logs for an individual aggregate.
- Corrective Action
(None).
- Syslog Message
WAFL external cache warming replay complete for aggregate %s with invalidation log %d%% full.
- Parameters
percent (INT): Percentage of ilog that is full.
extCache.rw.replay.start
- Severity
INFORMATIONAL
- Description
This message occurs when the external cache begins processing the invalidation logs for an individual aggregate.
- Corrective Action
(None).
- Syslog Message
WAFL external cache warming replay has begun for aggregate %s.
- Parameters
extCache.rw.replay.timeout
- Severity
NOTICE
- Description
This message occurs when the external cache timed out waiting for an aggregate to come online and purged old cache entries for it. This causes the external cache component to start with no data cached for the aggregate, which might cause a temporary performance impact.
- Corrective Action
(None).
- Syslog Message
WAFL external cache replay timed out for aggregate %s.
- Parameters
extCache.rw.snap.canceled
- Severity
NOTICE
- Description
This message occurs when the external cache cannot save a warming snapshot copy. This causes the external cache component to be unable to rewarm after a reboot, which might cause a temporary performance impact.
- Corrective Action
(None).
- Syslog Message
WAFL external cache snapshot copy canceled: %s.
- Parameters
description (STRING): String providing information about why the operation was canceled.
extCache.rw.terminated
- Severity
NOTICE
- Description
This message occurs when the external cache warming process is terminated. This causes the external cache component to start with no data cached for any aggregates, which might cause a temporary performance impact.
- Corrective Action
(None).
- Syslog Message
WAFL external cache warming process terminated.
- Parameters
(None).
extCache.rw.timeout
- Severity
NOTICE
- Description
This message occurs when the external cache warming process terminates after exceeding its allowed time. This causes the external cache component to start with a subset of cached data, which might cause a temporary performance impact.
- Corrective Action
(None).
- Syslog Message
WAFL external cache warming process exceeded its maximum allowable time and was aborted.
- Parameters
(None).
