ONTAP EMS reference
fg.quota events
fg.quota.cannot.enforce
Severity
NOTICE
This message occurs when a FlexGroup cannot enforce its quota as expected.
Corrective Action
(None).
Syslog Message
FlexGroup %s (fg-uuid %s) cannot enforce quota due to %s.
object_name (STRING): Name of the FlexGroup.
object_uuid (STRING): UUID of the FlexGroup.
reason (STRING): Reason for lack of quota enforcement.
fg.quota.enforcement.on
Severity
NOTICE
This message occurs when a file operation discovers that the quota enforcement state of a FlexGroup has changed to "on".
Corrective Action
(None).
Syslog Message
FlexGroup %s (fg-uuid %s) quota enforcement state is on.
fg.quota.on.failed
Severity
ERROR
This message occurs when enabling quotas (quota on an operation) on a FlexGroup constituent fails.
Corrective Action
Correct the problem based on the reason specified. If the error persists, contact technical support.
Syslog Message
Failed to execute the quota on operation on FlexGroup constituent %s in Vserver %s. Reason: %s.
volumeName (STRING): Name of the constituent.
vserverName (STRING): Name of the Vserver.
reason (STRING): Reason for the failure.
fg.quota.usermapping.result
Severity
NOTICE
This message occurs when the quota mapper decides whether to map the Windows quota record and the UNIX quota record of a user into a single multiuser record.
Corrective Action
(None).
Syslog Message
%s (uuid %s) tid %d: %s.
constituent_name (STRING): Name of the FlexGroup constituent.
object_uuid (STRING): UUID of the FlexGroup constituent.
qtree (LONGINT): Qtree identifier (tid).
result (STRING): User mapping result.
