ONTAP EMS reference
fg.unconvert events
fg.unconvert.critical.fail
Severity
ALERT
This message occurs when a member of a FlexGroup fails to be converted into an independent FlexVol® volume. The original state of this member could not be restored, so the FlexGroup itself is inoperable, and requires repair.
Corrective Action
Contact NetApp technical support.
Syslog Message
FlexGroup member #%u of %u in FlexGroup %s failed to be converted into an independent FlexVol volume. The FlexGroup is inoperable. Reason: %s
fgindex (INT): FlexGroup index of the volume being converted to a FlexVol volume.
fgmembers (INT): Total number of members in this FlexGroup.
fgname (STRING): Name of the FlexGroup containing the member being converted to a FlexVol volume.
reason (STRING): Reason why the conversion failed.
fg.unconvert.fail
Severity
ERROR
This message occurs when a member of a FlexGroup has fails to be converted into an independent FlexVol® volume. The FlexGroup is still functional.
Corrective Action
Ensure that the FlexGroup is a valid candidate for the unconvert operation, and then retry the command. If the error persists, contact NetApp technical support.
Syslog Message
FlexGroup member #%u of %u in FlexGroup %s failed to be converted into an independent FlexVol volume. Reason: %s
fg.unconvert.start
Severity
NOTICE
This message occurs when a member of a FlexGroup, usually the root constituent, is being converted to an independent FlexVol® volume.
Corrective Action
(None).
Syslog Message
Starting conversion of FlexGroup member #%u of %u in FlexGroup %s into an independent FlexVol volume.
fg.unconvert.success
Severity
NOTICE
This message occurs when a member of a FlexGroup is successfully converted to an independent FlexVol® volume.
Corrective Action
(None).
Syslog Message
FlexGroup member #%u of %u in FlexGroup %s was successfully converted into an independent FlexVol volume.
