flexcache.cfg events
flexcache.cfg.refresh.failed
- Severity
ERROR
- Description
This message occurs when a FlexCache® configuration refresh operation fails during cluster takeover or giveback, or when there is a connection state update triggered when origin or cache moves from connected state to disconnected state, or the other way round. Data access through FlexCache volumes might be impacted as a result.
- Corrective Action
First, verify that the two SVMs in question are peered by using the "vserver peer show" command. Next, enter the "flexcache config-refresh -peer-vserver <peer-vserver> -peer-volume <peer-volume> -peer-endpoint-type <peer-endpoint-type>" command on a node within the cluster that directly manages the peer endpoint.
- Syslog Message
FlexCache configuration refresh fails on peer SVM %s for peer volume %s and peer endpoint %s on cluster %s.
- Parameters
peeredVserverUuid (STRING): Universal unique identifier (UUID) of the peered storage virtual machine (SVM).
peerVolumeName (STRING): Name of the peer volume.
peerEndPointType (STRING): Peer endpoint type.
clusterUuid (STRING): UUID of the cluster with the peer endpoint.
localVserverUuid (STRING): UUID of the local SVM.
