ONTAP EMS reference
fmmb.lock events
fmmb.lock.disk.remove
Severity
INFORMATIONAL
This event is issued when a disk is removed from the HA mailbox disk lock set.
Corrective Action
(None).
Syslog Message
Disk %s removed from %s mailbox set.
disk (STRING): The name of the disk. If the disk name is not available, a ?.? will be used.
host (STRING): The node which owns the HA mailbox disk. The node can be either local or partner.
