ha.unabletoretrieveaggrs events
ha.unabletoretrieveaggrs EMS events occur when the node is unable to retrieve a list of aggregates from the replicated database (RDB).
ha.unableToRetrieveAggrs
- Severity
ERROR
- Description
This message occurs when the node is unable to retrieve a list of aggregates from the replicated database (RDB).
- Corrective Action
Wait for the nodes to reach quorum. Check for quorum using the (privilege: advanced) "cluster ring show" command.
- Syslog Message
This node was unable to retrieve the list of %s aggregates.
- Parameters
own_partner (STRING): The message "partner" will occur if the node is trying to retrieve its partner's aggregate, and "its own" if the node is trying to retrieve its own aggregates.
