ONTAP EMS reference
hya.caching events
hya.caching.cde.vol.warning
Severity
ERROR
This message occurs when auto adaptive compression is enabled on a volume in a Flash Pool aggregate or when Flash Pool caching is enabled on an auto adaptive compression volume. Caching is skipped.
Corrective Action
Caching is not supported on auto adaptive compressed blocks. If caching is needed, compression has to be disabled. Also note that existing compressed blocks will not get read cached.
Syslog Message
Flash Pool caching of user data is not supported on auto adaptive compression enabled volume "%s" in aggregate "%s".
vol (STRING): Volume name.
aggr (STRING): Aggregate name.
