ONTAP EMS reference
license.cappool events
license.cappool.aggr.noncomp
Severity
ALERT
This message occurs when an aggregate does not comply with the current Capacity Pool entitlement, as determined by the Licensing Manager. In an HA configuration, noncompliant aggregates are prevented from being sent home during an HA takeover/giveback situation. In a non-HA configuration, these aggregates cannot be brought online if they are already offline.
Corrective Action
Use the "system license license-manager check" command to determine whether the License Manager is accessible. Use the "system license show-aggregates -compliant false" command to find all aggregates that do not comply. From the web interface of the ONTAP® Select Deploy® instance, check the Capacity Pool licensing status, and ensure that sufficient capacity remains within the capacity pool used by this instance of ONTAP. If the capacity is insufficient, reduce the usage by instances of ONTAP that use the pool (for example, by deleting aggregates). If no reduction is possible, Contact NetApp technical support..
Syslog Message
Aggregate %s (UUID: %s) is not compliant with current Capacity Pool entitlement.
aggr_name (STRING): Name of the aggregate.
aggr_uuid (STRING): UUID of the aggregate.
