ONTAP EMS reference
lun.oovc events
LUN.oovc.rebuild.done
Severity
NOTICE
This message occurs when the rebuilding of the Out Of Volume Container (OOVC) file is complete.
Corrective Action
(None).
Syslog Message
The OOVC has been rebuilt for the volume %s (DSID %llu).
volume_name (STRING): Name of the volume for which the OOVC file was rebuilt.
volume_dsid (LONGINT): Data Set ID (DSID) of the volume for which the OOVC file was rebuilt.
LUN.oovc.version.mismatch
Severity
ERROR
This message occurs when a version mismatch is detected for the Out Of Volume Container (OOVC) metafile.
Corrective Action
Rebuild the OOVC metafile for the volume by running the 'lun rescan -build-oovc' command.
Syslog Message
A version mismatch has been detected for the OOVC metafile in volume %s (DSID %llu).
volume_name (STRING): Name of the volume for which a version mismatch of the OOVC metafile has been detected.
volume_dsid (LONGINT): Data Set ID (DSID) of the volume for which a version mismatch of the OOVC metafile has been detected.
