lun.vdisk events
LUN.vdisk.cnt.exceeded
- Severity
ERROR
 - Description
This message occurs when a volume contains more than the supported limit of LUNs in the volume. Performance degradation in volume management operations may occur as a result and it will not be possible to create more LUNs in this volume.
 - Corrective Action
It is recommended that LUNs be moved to other volumes.
 - Syslog Message
Volume %s (DSID %llu) contains more than the supported limit for LUNs (%d).
 - Parameters
volume_name (STRING): Name of the volume which contains more than the supported limit of LUNs.
volume_dsid (LONGINT): Data Set ID (DSID) of the volume which contains more than the supported limit of LUNs.
max_create_limit (INT): The maximum number of LUNs that can be created in a volume.
LUN.vdisk.prov.cnt.exceeded
- Severity
ERROR
 - Description
This message occurs when provisioning of metadata for some LUNs fails because the limit for provisioning LUNs in the volume has been exceeded.
 - Corrective Action
It is recommended that LUNs be moved to other volumes and then mapped using the 'lun map' command.
 - Syslog Message
Provisioning of metadata for some LUNs failed because the limit on the maximum supported LUNs in the volume %s (DSID %llu) has been exceeded. These LUNs cannot be discovered by hosts and will not be accessible for I/O. Metadata cannot be provisioned for more than %d LUNs.
 - Parameters
volume_name (STRING): Name of the volume for which the LUN provisioning failed.
volume_dsid (LONGINT): Data Set ID (DSID) of the volume for which the LUN provisioning failed.
max_prov_limit (INT): Maximum number of LUNs for which metadata can be provisioned in a volume.
