ONTAP EMS reference
lun.vtoc events
LUN.vtoc.rebuild.done
Severity
NOTICE
This message occurs when the rebuilding of the Vdisk Table of Contents (VTOC) file is complete.
Corrective Action
(None).
Syslog Message
The VTOC has been rebuilt for the volume %s (DSID %llu).
volume_name (STRING): Name of the volume for which the VTOC file was rebuilt.
volume_dsid (LONGINT): Data Set ID (DSID) of the volume for which the VTOC file was rebuilt.
LUN.vtoc.version.mismatch
Severity
ERROR
This message occurs when a version mismatch is detected for the Vdisk Table of Contents (VTOC) metafile.
Corrective Action
Rebuild the VTOC metafile for the volume by running the 'lun rescan -build-vtoc' command.
Syslog Message
A version mismatch has been detected for the VTOC metafile in volume %s (DSID %llu).
volume_name (STRING): Name of the volume for which a version mismatch of the VTOC metafile has been detected.
volume_dsid (LONGINT): Data Set ID (DSID) of the volume for which a version mismatch of the VTOC metafile has been detected.
