ONTAP EMS reference
mcc.nso events
mcc.nso.abort.dump
Severity
NOTICE
This message occurs when dump/restore is aborted during a MetroCluster switch-over operation.
Corrective Action
(None).
Syslog Message
Dump/restore operations were aborted because %s is in progress.
nso (STRING): Describes whether a MetroCluster switch-over operation is progress.
mcc.nso.veto.repl
Severity
NOTICE
This message occurs when an MetroCluster(tm) switch-over is vetoed by a critical replication transfer (for example, volume move in the cutover phase).
Corrective Action
Either abort the replication transfer that is preventing the MetroCluster switch-over from being completed, retry the MetroCluster switch-over operation with the '-override-vetoes true' option, or wait for the transfer to finish.
Syslog Message
Could not complete switch-over because a replication transfer with UUID %s is in progress.
transferId (STRING): UUID of the SnapMirror® replication transfer that vetoed MetroCluster switch-over.
