mgmt.fpolicy events
mgmt.fpolicy EMS events occur when ONTAP encounters issues associated with FPolicy® policy configuration and operations.
mgmt.fpolicy.policy.disabled
- Severity
INFORMATIONAL
- Description
This message occurs when a Vserver administrator disables an FPolicy® policy. No subsequent client requests will be processed and no notifications will be sent to FPolicy servers attached with this policy.
- Corrective Action
(None).
- Syslog Message
FPolicy policy %s is disabled on Vserver %s.
- Parameters
policyname (STRING): Name of the policy.
vservername (STRING): Name of the Vserver.
mgmt.fpolicy.policy.enabled
- Severity
INFORMATIONAL
- Description
This message occurs when a Vserver administrator enables an FPolicy® policy. Based on the event configuration, subsequent client requests will be processed, notifications will be generated, and notifications might be sent (based on the policy configuration) to FPolicy servers attached with this policy.
- Corrective Action
(None).
- Syslog Message
FPolicy policy %s is enabled on Vserver %s.
- Parameters
mgmt.fpolicy.priv.failed
- Severity
ERROR
- Description
This message occurs when the creation of privileged share ONTAP_ADMIN$ fails. Attempted connections to ONTAP_ADMIN$ share by the FPolicy servers will fail.
- Corrective Action
Check the reason for failure and take action accordingly. If the problem persists, contact NetApp technical support for assistance.
- Syslog Message
Failed to create privileged share ONTAP_ADMIN$ for Vserver "%s". Reason: "%s".
- Parameters
vserverName (STRING): Name of the Vserver.
reason (STRING): Reason for failure.
mgmt.fpolicy.replay.failed
- Severity
ERROR
- Description
This message occurs when an FPolicy® configuration replication mechanism fails after a maximum number of retries. FPolicy Service Manager (FSM) process will restart to resync configuration.
- Corrective Action
If the error persists, contact NetApp technical support for assistance.
- Syslog Message
FPolicy configuration replication process failed.
- Parameters
(None).
