mlm.vmdisk events
mlm.vmdisk EMS events occur when ONTAP encounters issues associated with virtual disks in virtual machines.
mlm.vmdisk.discovery
- Severity
INFORMATIONAL
- Description
This message occurs when the system discovers a new virtual disk in a virtual machine (VM).
- Corrective Action
(None).
- Syslog Message
A new virtual disk with virtual device ID %d was discovered on initiator port %s on array %s with target port WWNN %s and WWPN: %s.
- Parameters
VirtualDeviceID (INT): Virtual device ID of the virtual disk.
adapterName (STRING): Name of the initiator port discovering the virtual disk.
arrayName (STRING): Name of the array.
wwnn (STRING): World Wide Node Name (WWNN) of the array target port exporting the new virtual disk.
wwpn (STRING): World Wide Port Name (WWPN) of the array target port exporting the new virtual disk.
mlm.vmdisk.PathAdded
- Severity
INFORMATIONAL
- Description
This message occurs when a new path is added for a virtual disk in a virtual machine (VM).
- Corrective Action
(None).
- Syslog Message
Virtual disk '%s' (%s) is now connected on initiator port %s through %s's target port: WWNN: %s, WWPN: %s at virtual device ID: %d.
- Parameters
diskName (STRING): Name of the virtual disk
serialno (STRING): Serial number of the virtual disk.
adapterName (STRING): Name of the initiator port discovering the virtual disk path.
wwnn (STRING): World Wide Node Name (WWNN) of the array target port.
wwpn (STRING): World Wide Port Name (WWPN) of the array target port.
