monitor.chassispower events
monitor.chassispower EMS events occur when ONTAP encounters issues associated with chassis power supply operation.
monitor.chassisPower.degraded
- Severity
ALERT
- Description
This message occurs when a power supply is degraded.
- Corrective Action
Degraded power might be caused by bad power supplies, bad wall power, or bad components on the motherboard. If spare power supplies are available, try exchanging them to see if that alleviates the problem. Otherwise contact NetApp technical support for further direction.
- Syslog Message
Chassis power is degraded: %s
- Parameters
reasonText (STRING): Description of the degradation.
monitor.chassisPower.ok
- Severity
NOTICE
- Description
This message occurs when the motherboard power is OK.
- Corrective Action
(None).
- Syslog Message
Chassis power is OK.
- Parameters
(None).
