ONTAP EMS reference
monitor.power events
monitor.power.degraded
Deprecated
Deprecated as of version 9.2. Last used in 7.3.6 on Tin and Dell one-PSU systems. It is the last user of snmp trap 43.
Severity
EMERGENCY
This message occurs when the main unit power supply is in a degraded mode.
Corrective Action
(Call support).
Syslog Message
Power supply is in degraded mode: %s
report (STRING): Description of the problem.
monitor.power.normal
Severity
INFORMATIONAL
This message occurs when the system has sufficient power (220V) to power up both controllers.
Corrective Action
(None).
Syslog Message
The power provided to the system is sufficient.
(None).
monitor.power.not.sufficient
Severity
ALERT
This message occurs when a storage system in a low-line (110V) power configuration does not have sufficient power to support both controllers. The built-in hardware logic prevents the controller in the bottom slot from powering up.
Corrective Action
A high-line (220V) power configuration is needed to power up both controllers. Power off the system, connect the power supply unit (PSU) with 220V power, and then power up the system.
Syslog Message
The bottom controller is not powered up due to insufficient power.
(None).
monitor.power.unreadable
Severity
ERROR
This message occurs when a power sensor in the controller module is not readable.
Corrective Action
Shut down the system and power-cycle the controller module. If the sensor is still not readable, replace the controller module.
Syslog Message
A power sensor %s in the controller module is not readable.
sensor_name (STRING): Sensor name.
