monitor.shelf events
monitor.shelf EMS events occur when ONTAP encounters issues associated with disk shelf access and configuration.
monitor.shelf.accessError
- Severity
ALERT
- Description
This message occurs when the monitor detects that a disk shelf access error has occurred. The message is also an hourly reminder that the error has not been corrected. Enclosure Services is unable to monitor or control one or more disk shelves on a particular Fibre Channel loop or Serial SCSI Attach (SAS) domain because it cannot communicate with the enclosure services processes in those shelves.
- Corrective Action
Check the corrective actions of enclosure services error messages that might precede this error in the log. Ensure that all loop or domain connections are latched and secured properly. Correct any error conditions indicated by LEDs on any of the shelves or shelf I/O modules. This might require power-cycling of shelves or replacement of modules, as is appropriate to the particular shelf type.
- Syslog Message
Enclosure services has detected an error in access to shelves on channel %s.
- Parameters
channel (STRING): Adapter slot or switch port that has detected the fault; for example, "7a" or "myswitch:5".
monitor.shelf.accessError.ok
- Severity
NOTICE
- Description
This message occurs when the monitor detects that a previously detected shelf access error has been corrected.
- Corrective Action
(None).
- Syslog Message
Enclosure services-detected shelf access error has been corrected on channel %s.
- Parameters
channel (STRING): Adapter slot or switch port where the error was corrected.
monitor.shelf.configError
- Severity
ALERT
- Description
This message occurs when the Enclosure Services process notifes the monitor of a disk shelf configuration error. The message is also an houly reminder that the error has not been corrected. Configuration errors might cause Enclosure Services to be unable to monitor a disk shelf, or might indicate shelf configuration or interconnect problems; for example, too few power supplies in a disk shelf, or improper mixing of modules in a shelf or on a loop.
- Corrective Action
See the EMS message concerning disk shelf configuration errors that preceded the first instance of this message, and follow the corrective actions therein.
- Syslog Message
Enclosure services has detected an error in access to shelves or shelf configuration on channel %s.
- Parameters
monitor.shelf.configError.ok
- Severity
NOTICE
- Description
This message occurs when the monitor detects that a previously detected shelf configuration error has been corrected.
- Corrective Action
(None).
- Syslog Message
Enclosure services-detected configuration error has been corrected on channel %s.
- Parameters
channel (STRING): Adapter slot or switch port where the fault existed.
monitor.shelf.fault
- Severity
ALERT
- Description
This message occurs when the system detects a critical disk shelf fault. It is also an hourly reminder that the condition has not been corrected.
- Corrective Action
Check the event log for more specific shelf error messages, and follow the corrective actions there. Use the "storage shelf show" and "storage shelf show -errors" commands to display the current shelf status.
- Syslog Message
Critical fault reported on disk storage shelf attached to channel %s. Check fans, power supplies, disks, and temperature sensors.
- Parameters
monitor.shelf.fault.ok
- Severity
NOTICE
- Description
This message occurs when the monitor detects that a previously detected shelf fault has been corrected.
- Corrective Action
(None).
- Syslog Message
Fault previously reported on disk storage shelf attached to channel %s has been corrected.
- Parameters
channel (STRING): Adapter slot or switch port where the error has been corrected; for example,"7a" or "myswitch:5".
monitor.shelf.warning
- Severity
ERROR
- Description
This message occurs when the system detects a disk shelf warning. It is also an hourly reminder that the condition has not been corrected.
- Corrective Action
Check the messages log for more specific shelf error messages, and follow the corrective actions there.
- Syslog Message
Fault reported on disk storage shelf attached to channel %s. Check fans, power supplies, disks, and temperature sensors.
- Parameters
