ONTAP EMS reference
nblade.nfsmountrootonly events
Nblade.NfsMountRootOnly
Severity
NOTICE
This message occurs when a non-root user performs MOUNT or NFS operation when the respective options '-mount-rootonly' or 'nfs-rootonly' are enabled.
Corrective Action
(None).
Syslog Message
%s operation by non-root user failed. Vserver ID is %d; ProgramNumber is %d; client IP address:port is %s:%d; local IP address is %s; Procedure number is %d.
serviceProtocol (STRING): Network data protocol used in the connection.
vserverId (INT): Identifier for the vserver associated with this operation.
programNumber (INT): RPC Program Number.
remoteAddr (STRING): IP address of the client machine.
remotePort (INT): Remote port number that sent the data.
localAddr (STRING): IP address of the local interface serving the protocol operation.
procedureNum (INT): RPC Procedure Number for the requested operation.
