      platform.dimmconfigerror events
platform.dimmConfigError
- Severity
ALERT
 - Description
This message occurs when the DIMM configuration of the controller is different from the configuration supported by this model. This often occurs when an incorrect DIMM memory size is used in a DIMM slot.
 - Corrective Action
Place correctly sized and supported DIMMs in the designated slots. For replacement instructions, search the NetApp technical support support web site using the keywords "replacing", "DIMM", and "system".
 - Syslog Message
Memory DIMM configuration mismatch in slots %s.
 - Parameters
slots (STRING): List of slots with the incorrect DIMM.
