ONTAP EMS reference
raid.cksum events
raid.cksum EMS events occur when ONTAP encounters issues associated with checksum errors and block validation.
raid.cksum.bad.file.block
Severity
ERROR
This event is issued when WAFL accesses a block that was zeroed because it could not be recovered correctly.
Corrective Action
Please restore the corrupted file from snapshot or from the backup media.
Syslog Message
Reading bad block on %s %s%s, %s, disk block %llu, %s inode number %d, snapid %d, file block %llu, level %d.
vol_type (STRING): Whether the block was being accessed for a flexible volume or an aggregate.
owner (STRING): Owner of the affected volume or aggregate.
vol (STRING): The name of the volume or aggregate
disk_info (STRING): Formatted information of the disk
blockNum (LONGINT): The block number
ino_type (STRING): The inode type
fileid (INT): The file identifier
snapid (INT): The snapshot identifier
bno (LONGINT): The block number in the file
level (INT): The level
shelf (STRING): Shelf identifier where the disk is located
bay (STRING): Disk bay within the shelf where disk is located
vendor (STRING): Name of the vendor of the disk
model (STRING): Model string of the disk drive
firmware_revision (STRING): Firmware revision number of the disk
serialno (STRING): Serial number of the disk
disk_type (INT): Type of disk drive
disk_rpm (STRING): Rotational speed of disk in RPM
carrier (STRING): Unique ID of the carrier in which the disk is installed.
site (STRING): For a MetroCluster(tm) configuration, indicates the site {Local|Remote} where the disk is located. For non-MetroCluster configurations, site is 'Local'.
raid.cksum.buf.read.error.embedded
Severity
NOTICE
This message occurs when the system detects an embedded checksum error. This can occur when a zeroing disk is added to the RAID group for reconstruction, and the zeroing is never completed.
Corrective Action
(None).
Syslog Message
Embedded checksum error on %s %s%s, %s, phys checksum block %llu
vol_type (STRING): Volume type.
owner (STRING): Owner of the affected aggregate.
vol (STRING): Name of the aggregate.
disk_info (STRING): Formatted information about the disk.
blockNum (LONGINT): Disk block number.
shelf (STRING): Identifier of the shelf where the disk is located.
bay (STRING): Disk bay within the shelf where the disk is located.
vendor (STRING): Name of the vendor of the disk.
model (STRING): Model name of the disk.
firmware_revision (STRING): Firmware revision number of the disk.
serialno (STRING): Serial number of the disk.
disk_type (INT): Type of disk.
disk_rpm (STRING): Rotational speed of the disk, in RPM.
raid.cksum.bypass
Severity
NOTICE
This message occurs when a read error has occurred while media error bypass is enabled.
Corrective Action
(None).
Syslog Message
raid_cksum_compare: media error bypass enabled; Ignoring read error - %s %s%s, %s disk block %llu
blockNum (LONGINT): Block number.
bay (STRING): Disk bay within the shelf where disk is located.
raid.cksum.bypass.bno
Severity
NOTICE
This message occurs when the system detects a block number mismatch while media error bypass is enabled. The expected virtual block number (VBN)/disk block number (DBN) is not the same as the stored VBN/DBN from the checksum entry, indicating that the block is read from the wrong location. The error is ignored.
Corrective Action
(None).
Syslog Message
Block number mismatch: %s %s%s, %s stored_dbn = %u, expected_dbn = %llu; stored_vbn = %llu, expected_vbn = %llu; media error bypass enabled; ignoring read error.
stored_dbn (INT): Physical disk block number stored in the checksum entry.
expected_dbn (LONGINT): Expected physical disk block number.
stored_vbn (LONGINT): Volume block number stored in the checksum entry.
expected_vbn (LONGINT): Expected volume block number.
bay (STRING): Disk bay within the disk shelf where the disk is located.
vendor (STRING): Name of the disk vendor.
raid.cksum.bypass.embed
Severity
NOTICE
This message occurs when the system detects an invalid checksum entry while media error bypass is enabled. The checksum computed over the checksum entry does not match the embedded checksum, indicating that the checksum entry is corrupted. The error is ignored.
Corrective Action
(None).
Syslog Message
Invalid checksum entry: %s %s%s, %s disk block %llu; Media error bypass enabled; Ignoring read error.
blockNum (LONGINT): Physical disk block number containing the error.
raid.cksum.bypass.unknown
Severity
NOTICE
This message occurs when a read error has occurred and has been ignored because media error bypass is enabled.
Corrective Action
(None).
Syslog Message
raid_cksum_compare: media error bypass enabled; Ignoring read error - %s %s%s, on disk block %llu
raid.cksum.bypass.unkwn.bno
Severity
NOTICE
This message occurs when the system detects a block number mismatch while media error bypass is enabled. The expected virtual block number (VBN)/disk block number (DBN) is not the same as the stored VBN/DBN from the checksum entry, indicating that the block is read from the wrong location. The error is ignored. Details on which disk the error was encountered on are not Available because the disk transitioned to an unavailable state between the detection of the error and the logging of this message.
Corrective Action
(None).
Syslog Message
Block number mismatch: %s %s%s, stored_dbn = %u, expected_dbn = %llu; stored_vbn = %llu, expected_vbn = %llu; Media error bypass enabled; Ignoring read error.
raid.cksum.bypass.unkwn.embd
Severity
NOTICE
This message occurs when the system detects an invalid checksum entry while media error bypass is enabled. The embedded checksum computed over the checksum entry does not match the stored embedded checksum in the checksum entry, indicating the corruption of the checksum entry. The error is ignored. Details on which disk the error was encountered on are not Available, because the disk transitioned to an unavailable state between the detection of the error and the logging of this message.
Corrective Action
(None).
Syslog Message
Invalid checksum entry: %s %s%s, on block %llu; Media error bypass enabled; Ignoring read error.
raid.cksum.bypass.unkwn.zero
Severity
NOTICE
This message occurs when the system detects an empty checksum entry while media error bypass is enabled. The checksum entry is zeroed, but the corresponding block is not zeroed. The error is ignored. Details on which disk the error was encountered on are not Available because the disk transitioned to an unavailable state between the detection of the error and the logging of this message.
Corrective Action
(None).
Syslog Message
Empty checksum entry for non-zeroed block: %s %s%s, on disk block %llu; Media error bypass enabled; Ignoring read error.
raid.cksum.bypass.zero
Severity
NOTICE
Corrective Action
(None).
Syslog Message
Empty checksum entry for non-zeroed block: %s %s%s, %s disk block %llu; Media error bypass enabled; Ignoring read error.
raid.cksum.disabled
Severity
NOTICE
This event is issued when we disable checksums on an aggregate.
Corrective Action
(None).
Syslog Message
Disabled checksums on %s %s%s.
owner (STRING): Owner of the aggregate.
raid.cksum.embedded.error
Severity
INFORMATIONAL
This message occurs when the stored checksum of a checksum block does not match the computed checksum of the checksum block. Data ONTAP® takes appropriate recovery actions, as described in additional logged events.
Corrective Action
(None).
Syslog Message
Checksum Entry of volume %s, disk %s, disk block %llu is bad: expected checksum %x, actual checksum %x
disk (STRING): Name of the disk.
expected_cksum (INT): Expected checksum of the checksum entry.
actual_cksum (INT): Actual embedded checksum in the checksum entry.
raid.cksum.enabled
Severity
NOTICE
This event is issued when we enable checksums on an aggregate.
Corrective Action
(None).
Syslog Message
Enabled checksums on %s %s%s.
raid.cksum.err.recFail
Severity
NOTICE
This message occurs when a disk is recommended for failure because we encountered more than allowed number of checksum errors.
Corrective Action
Wait for the event message raid.disk.unload.done or raid.carrier.remove to be issued and then replace the carrier containing the failed disk. If the disk is contained in a single-disk carrier, raid.disk.unload.done will be issued immediately. Otherwise, wait for raid.carrier.remove which indicates the carrier has been fully prepared for removal.
Syslog Message
Disk recommended for failure for exceeding threshold of %d checksum errors on %s%s.
threshold (INT): The threshold for checksum errors
owner (STRING): String indicating the owner of the affected volume.
disk_info (STRING): The name of the disk.
raid.cksum.fsm.phase1
Severity
INFORMATIONAL
This event is generated when phase 1 of a checksum upgrade is complete.
Corrective Action
(None).
Syslog Message
Completed RAID checksum upgrade phase 1 (of 2) on %s %s%s; phase 2 will occur during the next disk scrub.
host (STRING): Owner of the aggregate.
raid.cksum.fsm.phase1.abort
Severity
INFORMATIONAL
This event is generated when phase 1 of a checksum upgrade is aborted.
Corrective Action
(None).
Syslog Message
RAID checksum upgrade phase 1 (of 2) on %s %s%s %s aborted.
disk_info (STRING): Formatted information of disk object that has completed its zeroing operation
raid.cksum.fsm.reinit
Severity
INFORMATIONAL
This event is generated when reinitialization of checksums is complete.
Corrective Action
(None).
Syslog Message
Completed RAID checksum reinitialization on %s %s%s.
raid.cksum.fsm.reinit.abort
Severity
INFORMATIONAL
This event is generated when checksum reinitialization is aborted.
Corrective Action
(None).
Syslog Message
RAID checksum reinitialization on %s %s%s %s aborted.
raid.cksum.fsm.revert
Severity
INFORMATIONAL
This event is generated when a checksum revert is complete.
Corrective Action
(None).
Syslog Message
Checksum revert of %s %s%s completed; vol copy, aggr copy and snapmirror now allowed.
raid.cksum.ignore.bno
Severity
NOTICE
This message occurs when the system detects a block number mismatch. The expected virtual block number (VBN)/disk block number (DBN) is not the same as the stored VBN/DBN from the checksum entry, indicating that the block is read from the wrong location. This error is ignored if one of the following conditions is true: - It was encountered during WAFL® check. - It was encountered during wafliron and in ignore unrecoverable checksum error mode. - The block cannot be recovered from parity and the volume is ignoring unrecoverable errors. - It was encountered in ignore checksum error mode. - It was encountered in boot bypass media error mode.
Corrective Action
(None).
Syslog Message
Block number mismatch on %s %s %s, %s: stored_dbn = %u, expected_dbn = %llu; stored_vbn = %llu, expected_vbn = %llu. Ignoring unrecoverable error.
disk_info (STRING): Information about the disk object, including disk name, path, shelf, bay, serial number, vendor, model, RPM, and carrier serial number.
stored_vbn (LONGINT): VBN stored in the checksum entry.
expected_vbn (LONGINT): Expected VBN.
shelf (STRING): Identifier of the disk shelf where the disk is located.
raid.cksum.ignore.embed
Severity
NOTICE
This message occurs when the system detects an invalid checksum entry. The embedded checksum computed over the checksum entry does not match, indicating the corruption of the checksum entry. This error is ignored if one of the following conditions is true: - It was encountered during WAFL® check. - It was encountered during wafliron and in ignore unrecoverable checksum error mode. - The block cannot be recovered from parity and the volume is ignoring unrecoverable errors. - It was encountered in ignore checksum error mode. - It was encountered in boot bypass media error mode.
Corrective Action
(None).
Syslog Message
Invalid checksum entry on %s %s %s, %s, disk block %llu. Ignoring unrecoverable error.
blockNum (LONGINT): Physical disk block number of the disk containing the error.
raid.cksum.ignore.error
Severity
NOTICE
This message occurs when the system ignores a checksum error. This error is ignored if one of the following conditions is true: * It was encountered during WAFL® check. * It was encountered during wafliron and in ignore unrecoverable checksum error mode. * The block cannot be recovered from parity and the volume is ignoring unrecoverable errors. * It was encountered in ignore checksum error mode. * It was encountered in boot bypass media error mode.
Corrective Action
(None).
Syslog Message
%s on %s %s%s, %s, disk block %llu. Ignoring unrecoverable error.
error (STRING): Name of the error.
disk_info (STRING): Information about the disk object including disk name, path, shelf, bay, serial number, vendor, model, RPM, and carrier serial number.
disk_type (INT): Type of disk drive.
disk_rpm (STRING): Rotational speed of the disk in RPM.
raid.cksum.ignore.file.bno
Severity
ALERT
This message occurs when the system detects a block number mismatch in a block of a file. The expected Virtual Block Number (VBN)/Disk Block Number (DBN) is not the same as the stored VBN/DBN from the checksum entry indicating that the block is read from the wrong location. This error is ignored if one of the following conditions is true: - It was encountered during WAFL® check. - It was encountered during wafliron and in ignore unrecoverable checksum error mode. - The block cannot be recovered from parity and the volume is ignoring unrecoverable errors. - It was encountered in ignore checksum error mode. - It was encountered in boot bypass media error mode.
Corrective Action
Contact technical support for information about how to resolve the unrecoverable checksum error in the referenced file.
Syslog Message
Block number mismatch on %s %s %s, %s, stored_dbn = %u, expected_dbn = %llu; stored_vbn = %llu, expected_vbn = %llu, %s inode number %d, snapid %d, file block %llu, level %d. Ignoring unrecoverable error.
disk_info (STRING): Formatted information of the disk drive.
fileid (INT): File identifier.
snapid (INT): Snapshot identifier.
bno (LONGINT): Block number in the file.
level (INT): Level.
shelf (STRING): Disk shelf identifier where the disk drive is located.
bay (STRING): Disk bay within the disk shelf where the disk drive is located.
vendor (STRING): Name of the disk drive vendor.
model (STRING): Model string of the disk drive.
firmware_revision (STRING): Firmware revision number of the disk drive.
serialno (STRING): Serial number of the disk drive.
disk_rpm (STRING): Rotational speed of the disk drive, in RPM.
raid.cksum.ignore.file.embed
Severity
ERROR
This message occurs when the system detects an invalid checksum entry in a block of a file. The embedded checksum computed over the checksum entry do not match, indicating the corruption of the checksum entry. This error is ignored if one of the following conditions is true: - It was encountered during WAFL® check. - It was encountered during wafliron and in ignore unrecoverable checksum error mode. - The block cannot be recovered from parity and the volume is ignoring unrecoverable errors. - It was encountered in ignore checksum error mode. - It was encountered in boot bypass media error mode.
Corrective Action
Syslog Message
Invalid checksum entry on %s %s %s, %s, disk block %llu, %s inode number %d, snapid %d, file block %llu, level %d. Ignoring unrecoverable error.
level (INT): Level.
raid.cksum.ignore.zero
Severity
NOTICE
This message occurs when the system detects an empty checksum entry. The checksum entry is zeroed, but the corresponding block is not zeroed. This error is ignored if one of the following conditions is true: - It was encountered during WAFL® check. - It was encountered during wafliron and in ignore unrecoverable checksum error mode. - The block cannot be recovered from parity and the volume is ignoring unrecoverable errors. - It was encountered in ignore checksum error mode. - It was encountered in boot bypass media error mode.
Corrective Action
(None).
Syslog Message
Empty checksum entry for non-zeroed block on %s %s %s, %s, disk block %llu. Ignoring unrecoverable error.
shelf (STRING): Identifier of the disk shelf where the disk drive is located.
model (STRING): String representing the name of the model of the disk drive.
raid.cksum.nvram.error
Severity
NOTICE
This message occurs when we cannot write out the checksum for an aggregate because of uninitialized NVRAM. System panics because of this error and will attempt to perform recovery in the next boot.
Corrective Action
(None).
Syslog Message
Cannot write checksum for %s %s%s, %s, disk block %llu: NVRAM is not initialized.
shelf (STRING): Shelf identifier where the disk is located.
bay (STRING): Disk bay within the disk shelf where disk drive is located.
raid.cksum.nvram.uninit
Severity
NOTICE
This message occurs when an aggregate checksum cannot be repaired because of uninitialized NVRAM.
Corrective Action
(None).
Syslog Message
Cannot repair checksum for %s %s%s, %s, disk block %llu: NVRAM is not initialized.
raid.cksum.replay.bad.entry
Severity
ERROR
This event is issued at the end of checksum replay when bad checksum entries are detected in NVRAM during that replay (indicating corrupted NVRAM). Reparity will start automatically and update checksum blocks involved in recent writes.
Corrective Action
Need to replace NVRAM if observed repeatedly during different boot-ups.
Syslog Message
Skipped %d bad checksum entries in NVRAM.
nentries (INT): The number of bad entries
raid.cksum.replay.disk.missing
Severity
INFORMATIONAL
This event is issued when we encounter an NVRAM checksum entry for a missing disk during checksum replay. The disk will be reconstructed if an appropriate spare is available.
Corrective Action
(None).
Syslog Message
Skipping checksum block %llu because disk with index %d is missing in %s %s%s, plex %s, RAID group %d.
cbn (LONGINT): Checksum block number
diskid (INT): Index of the disk in the RAID group.
plex (STRING): The name of the plex.
rgid (INT): The identifier of the RAID group.
raid.cksum.replay.mismatch
Severity
NOTICE
This event is issued when we encounter an NVRAM checksum entry which does not match the partner NVRAM shadow checksum entry.
Corrective Action
(None).
Syslog Message
Skipping checksum block %ld for disk %s because the checksum 0x%x and shadow checksum 0x%x do not match.
block_number (LONGINT): Checksum block number.
diskname (STRING): Name of the disk.
checksum (INT): Checksum value.
shadow_checksum (INT): Shadow checksum value.
raid.cksum.replay.nvgen.mismatch
Severity
NOTICE
This event is issued when we encounter an NVRAM generation mismatch for an aggregate during checksum replay. Reparity will start automatically and update checksum blocks involved in recent writes.
Corrective Action
(None).
Syslog Message
NVRAM generation mismatch for %s %s%s.
raid.cksum.replay.plex.missing
Severity
NOTICE
This event is issued when we encounter an NVRAM checksum entry for a missing plex during checksum replay. Reparity will start automatically when the plex comes online. At that time, reparity will update checksum blocks involved in recent writes.
Corrective Action
(None).
Syslog Message
Cannot find plex with identifier %d in %s %s%s.
plexid (INT): The identifier of the plex.
raid.cksum.replay.plex.unavailable
Severity
NOTICE
This event is issued when we encounter an NVRAM checksum entry for an offline or failed plex during checksum replay. Reparity will start automatically when the plex comes online. At that time, reparity will update checksum blocks involved in recent writes.
Corrective Action
(None).
Syslog Message
Plex %s in %s %s%s is offline or failed.
raid.cksum.replay.rg.invalid
Severity
NOTICE
This event is issued when we encounter an NVRAM checksum entry for a missing RAID group during checksum replay.
Corrective Action
(None).
Syslog Message
Invalid RAID group identifier %d in %s %s%s, plex %s.
raid.cksum.replay.summary
Severity
INFORMATIONAL
This event is generated when checksum replay is complete.
Corrective Action
(None).
Syslog Message
Replayed %u checksum blocks.
nblocks (INT): The number of blocks
raid.cksum.replay.vol.clean
Severity
NOTICE
This event is issued when we encounter an NVRAM checksum entry for a cleanly shutdown aggregate during checksum replay.
Corrective Action
(None).
Syslog Message
%s %s%s was cleanly shut down.
raid.cksum.replay.vol.missing
Severity
NOTICE
This event is issued when we encounter an NVRAM checksum entry for a missing volume or aggregate during checksum replay. Reparity will start automatically when the aggregate appears again. At that time, reparity will update checksum blocks involved in recent writes.
Corrective Action
(None).
Syslog Message
Cannot find aggregate with identifier %s.
volId (STRING): The identifier of the volume or aggregate.
raid.cksum.replay.vol.offline
Severity
NOTICE
This event is issued when we encounter an NVRAM checksum for an offline aggregate during checksum replay. Reparity will start automatically when the aggregate comes online. At that time, reparity will update checksum blocks involved in recent writes.
Corrective Action
(None).
Syslog Message
%s %s%s is not online.
raid.cksum.unverify.file.block
Severity
ERROR
This event is issued when WAFL accesses a block that could not be verified because of medium error on the checkusm block.
Corrective Action
Syslog Message
Reading unverified block on %s %s%s, %s, disk block %llu, %s inode number %d, snapid %d, file block %llu, level %d.
raid.cksum.validate.zoned
Severity
NOTICE
This event is issued when the aggregate cannot support Zone checksum.
Corrective Action
(None).
Syslog Message
Checksums cannot be enabled on %s %s%s due to its disk sizes.
raid.cksum.verify.bno
Severity
NOTICE
This message occurs when the system detects a block number mismatch in an aggregate when it is being accessed by RAID, and not in response to a WAFL® request; therefore, there is no usable WAFL® context. The expected virtual block Number (VBN)/ disk block number (DBN) is not the same as the stored VBN/DBN from the checksum entry, indicating that the block is read from the wrong location. Additional messages are logged as the system attempts to perform recovery.
Corrective Action
(None).
Syslog Message
Block number mismatch on %s %s%s, %s: stored_dbn = %u, expected_dbn = %llu; stored_vbn = %llu, expected_vbn = %llu. System will attempt to perform recovery.
physDiskBlockNum (LONGINT): Physical disk block number for partitioned disk.
raid.cksum.verify.embed
Severity
NOTICE
This message occurs when the system detects an invalid checksum entry in an aggregate when it is being accessed by RAID, and not in response to a WAFL® request; therefore, there is no usable WAFL context. The embedded checksum computed over the checksum entry does not match, indicating the corruption of the checksum entry. Additional messages are logged as the system attempts to perform recovery.
Corrective Action
(None).
Syslog Message
Invalid checksum entry on %s %s%s, %s, disk block %llu. System will attempt to perform recovery.
model (STRING): String representing the name of the model of the disk.
raid.cksum.verify.error
Severity
NOTICE
This message occurs when the system detects a checksum error in an aggregate when it is being accessed by RAID, and not in response to a WAFL® request; therefore, there is no usable WAFL® context. Additional messages are logged as the system attempts to perform recovery.
Corrective Action
(None).
Syslog Message
%s on %s %s%s, %s, disk block %llu, cpcount %d, buftreeid %llu. System will attempt to perform recovery.
stored_cpcount (INT): Stored CP count in the checksum entry.
stored_buftreeid (LONGINT): Stored buftree identifier in the checksum entry.
raid.cksum.verify.error.file
Severity
NOTICE
This message occurs when the system discovers a checksum error in a block of a file. The computed checksum over the stored data does not match the stored checksum, indicating corruption.Data ONTAP® makes appropriate recovery actions. Other events describe those actions.
Corrective Action
(None).
Syslog Message
%s on %s %s%s, %s, disk block %llu, cpcount %d, buftreeid %llu, %s inode number %d, snapid %d, file block %llu, level %d.
vol_type (STRING): Whether the file is contained in an aggregate or a flexible volume.
vol (STRING): Name of the volume or aggregate.
ino_type (STRING): Inode type.
level (INT): Level.
bay (STRING): Disk bay within the shelf where the disk drive is located.
disk_type (INT): Type of the disk drive.
raid.cksum.verify.file.bno
Severity
NOTICE
This message occurs when the system detects a block number mismatch in a block of a file. The expected virtual block number (VBN)/disk block number (DBN) is not the same as the stored VBN/DBN from the checksum entry, indicating that the block is read from the wrong location. Data ONTAP® makes appropriate recovery actions. Other events describe those actions.
Corrective Action
(None).
Syslog Message
Block number mismatch on %s %s%s, %s: stored_dbn = %u, expected_dbn = %llu; stored_vbn = %llu, expected_vbn = %llu, %s inode number %d, snapid %d, file block %llu, level %d.
level (INT): Level.
raid.cksum.verify.file.embed
Severity
NOTICE
This message occurs when the system detects an invalid file block checksum. The embedded checksum does not match the computed checksum, indicating corruption of the checksum entry. Data ONTAP® makes appropriate recovery actions, and other events describe those actions.
Corrective Action
(None).
Syslog Message
Invalid checksum entry on %s %s%s, %s, disk block %llu, %s inode number %d, snapid %d, file block %llu, level %d.
disk_info (STRING): Formatted information about the disk drive.
blockNum (LONGINT): Physical disk block number that contains the error.
level (INT): Level.
model (STRING): Model of the disk drive.
site (STRING): For a MetroCluster™ configuration, indicates the site {local|remote} where the disk is located. For non-MetroCluster configurations, the site is 'local'.
physDiskBlockNum (LONGINT): Physical disk block number of the partitioned disk.
raid.cksum.verify.file.zero
Severity
NOTICE
This message occurs when the system detects an empty checksum entry in a block of a file. The checksum entry is zeroed, but the corresponding block is not zeroed. Data ONTAP® makes appropriate recovery actions. Other events describe those actions.
Corrective Action
(None).
Syslog Message
Empty checksum entry for non-zeroed block on %s %s%s, %s, disk block %llu, %s inode number %d, snapid %d, file block %llu, level %d.
level (INT): Level.
raid.cksum.verify.zero
Severity
NOTICE
This message occurs when the system detects an empty checksum entry for a non-zeroed block in an aggregate when it is being accessed by RAID, and not in response to a WAFL® request; therefore there is no usable WAFL® context. The checksum entry is zeroed, but the corresponding block is not zeroed. Additional messages are logged as the system attempts to perform recovery.
Corrective Action
(None).
Syslog Message
Empty checksum entry for non-zeroed block on %s %s%s, %s, disk block %llu. System will attempt to perform recovery.
raid.cksum.wc.blkErr
Severity
NOTICE
This message occurs when the system detects a checksum error due to a WAFL® context mismatch. Data ONTAP® takes appropriate recovery actions, as described in additional logged events.
Corrective Action
Syslog Message
Checksum error due to WAFL context mismatch on %s %s%s, %s, disk block %llu, buftree ID %d, %s inode number %d, snapshot ID %d, file block %llu, level %d: checksum context has buftree ID %d, file block %llu, %s.
vol_type (STRING): Whether the file is contained in an aggregate or within a flexible volume.
buftreeid (LONGINT): Buftree identifier.
level (INT): Indirection level in the WAFL buffer.
stored_fbn (LONGINT): Stored file block number in the checksum entry.
remaining_stored_context (STRING): String containing CP count, Physical Volume Block Number (PVBN), encrypted flag, encyption key index stored in the checksum entry.
model (STRING): Model string of the disk.
raid.cksum.wc.sblkErr
Severity
ALERT
This message occurs when the system encounters a super block with bad WAFL® context information in its checksum entry.
Corrective Action
Start wafliron on the indicated volume or aggregate.
Syslog Message
Checksum error due to WAFL context mismatch for super block %llu on %s %s%s, %s.
raid.cksum.zeroed.blkErr
Severity
NOTICE
This message occurs when the system discovers that the stored checksum for a block allocated by WAFL® is zero. Data ONTAP® makes appropriate recovery actions. Other events describe those actions.
Corrective Action
(None).
Syslog Message
Checksum error due to zeroed block on %s %s%s, %s, disk block %llu, %s inode number %d, snapid %d, file block %llu, level %d.
level (INT): Level.
raid.cksum.zeroed.sblkErr
Severity
NOTICE
This message occurs when the system encounters a zeroed super block.Data ONTAP® makes appropriate recovery actions. Other events describe those actions.
Corrective Action
(None).
Syslog Message
Checksum error due to zeroed super block %llu on %s %s%s, %s.
