raid.olm events
raid.olm EMS events occur when a disk which is under online label maintenance(OLM) is prepared for ownership change by administrator forcibly.
raid.olm.disk.ownership.change
- Severity
NOTICE
- Description
This message occurs when a disk which is under online label maintenance(OLM) is prepared for ownership change by administrator forcibly.
- Corrective Action
(None).
- Syslog Message
Ownership of %s, which is under online label maintenance (OLM) is being changed by administator forcibly.
- Parameters
disk_info (STRING): Formatted information of the disk.
shelf (STRING): Disk shelf identifier where the disk is located.
bay (STRING): Disk bay within the disk shelf where the disk is located.
vendor (STRING): Name of the vendor of the disk.
model (STRING): Model string of the disk.
firmware_revision (STRING): Firmware revision number of the disk.
serialno (STRING): Serial number of the disk.
disk_type (INT): Type of disk.
disk_rpm (STRING): Rotational speed of the disk, in RPM.
carrier (STRING): Unique ID of the carrier in which the disk is installed.
site (STRING): For a MetroCluster(tm) configuration, indicates the site {Local|Remote} where the disk is located. For non-MetroCluster configurations, site is 'Local'.
