ONTAP EMS reference
raid.replay events
raid.replay.nvfile.done
Severity
INFORMATIONAL
This event is issued when an aggregate becomes available and system successfully replayed the preserved NVRAM entries associated with that aggregate. The NVRAM entries replayed are saved in a system file on the root volume.
Corrective Action
(None).
Syslog Message
Successfully replayed %d checksum, %d stripe %d pzero block entries from preserved NVRAM file for %s %s%s having raidtreeID %s.
nchecksum_replayed (INT): Identifies the number of checksum NVRAM entries replayed
nstripe_replayed (INT): Identifies the number of stripe NVRAM entries replayed
nblkbuf_replayed (INT): Identifies the number of pzero entries replayed
vol_type (STRING): Volume type.
owner (STRING): Owner of the aggregate.
vol (STRING): Name of the aggregate.
raidtreeID (STRING): RAIDtree identifier of the aggregate.
raid.replay.nvfile.start
Severity
INFORMATIONAL
This event is issued while starting the raid nvfile replay for an aggregate. When a aggregate becomes available and system determines that there are relevant nvram entries saved in a system file for such aggregate, those saved nvram entries must be replayed.
Corrective Action
(None).
Syslog Message
Starting raid nvfile replay for %s %s%s having raidtreeID %s stored on %s host root volume.
raidtreeID (STRING): Raidtree identifier of the aggregate.
host (STRING): The preserved nvfile being replayed for this aggregate was found on the host root volume.
raid.replay.partner.nvram
Severity
NOTICE
This message occurs when RAID replays partner nonvolatile RAM (NVRAM).
Corrective Action
(None).
Syslog Message
Replaying partner NVRAM.
(None).
