ONTAP EMS reference
raid.sp events
raid.sp.add.aggr.grow.noDone
Severity
NOTICE
This message occurs when one or more aggregate's capacity is not increased as part of the storage pool add job.
Corrective Action
Use the (privilege: diagnostic) "storage pool add -storage-pool <storage pool name> -auto-grow-aggregates" command to retry the operation. If the condition persists, contact NetApp technical support.
Syslog Message
Could not grow one or more aggregates provisioned from storage pool %s.
name (STRING): Name of the storage pool.
uuid (STRING): UUID of the storage pool.
jobid (LONGINT): ID of the job.
raid.sp.add.success
Severity
NOTICE
This message occurs when disks are added to the storage pool and all the aggregates provisioned from the storage pool have been grown to take capacity from new disks.
Corrective Action
(None).
Syslog Message
Disks %s added to storage pool %s.
disks (STRING): List of disks added to the storage pool.
raid.sp.aggr.add.rollback
Severity
NOTICE
This message occurs when available capacity is reassigned to a storage pool because adding storage pool capacity to an aggregate failed. This can happen if the node owning the aggregate is rebooted while additional storage pool capacity is zeroing. Other events provide additional failure information.
Corrective Action
(None).
Syslog Message
Aggregate add job for aggregate %s successfully rolled back available capacity to storage pool %s.
aggr (STRING): Name of the aggregate to which capacity is being added.
aggrUuid (STRING): UUID of the aggregate.
owner (STRING): Owning node of the aggregate.
curUnit (INT): Current available allocation unit.
prevUnit (INT): Allocation unit available before the job started.
raid.sp.aggr.add.success
Severity
NOTICE
This message occurs when capacity from a storage pool is added to an aggregate.
Corrective Action
(None).
Syslog Message
Added %d allocation units from storage pool %s to aggregate %s.
allocationUnits (INT): Number of allocation units added.
aggr (STRING): Name of the aggregate to which capacity is added.
raid.sp.aggr.grow.success
Severity
NOTICE
This message occurs when an aggregate capacity is successfully increased to span all disks belonging to a storage pool.
Corrective Action
(None).
Syslog Message
%s added to aggregate %s from storage pool %s.
capacity (STRING): Amount of capacity added to the aggregate.
aggr (STRING): Name of the aggregate whose capacity is increased.
raid.sp.create.failure
Severity
ERROR
This message occurs when a storage pool creation operation fails.
Corrective Action
Use the "storage pool delete -storage-pool <storage pool name>" command to delete the partially created storage pool and then retry the create operation. If the condition persists, contact NetApp technical support.
Syslog Message
Storage pool %s was not successfully created. Reason: %s
reason (STRING): Reason for failure.
nodes (STRING): List of nodes sharing the storage pool.
disks (STRING): List of disks used to create the storage pool.
raid.sp.create.success
Severity
NOTICE
This message occurs when a storage pool is created successfully.
Corrective Action
(None).
Syslog Message
Storage pool %s was created.
raid.sp.delete.success
Severity
NOTICE
This message occurs when a storage pool is deleted successfully.
Corrective Action
(None).
Syslog Message
Storage pool %s deleted.
raid.sp.healthy
Severity
NOTICE
This message occurs when Data ONTAP® detects that a storage pool that was unhealthy earlier has become healthy again.
Corrective Action
(None).
Syslog Message
Storage pool %s is now healthy.
raid.sp.reassign.success
Severity
NOTICE
This message occurs when available capacity is reassigned successfully from one node to another node in a storage pool.
Corrective Action
(None).
Syslog Message
Reassigned %d allocation units from node %s to node %s for storage pool %s.
allocationUnits (INT): Number of allocation units reassigned.
source (STRING): Node that owns the available capacity to be reassigned.
destination (STRING): Node to which the available capacity is reassigned.
raid.sp.unhealthy
Severity
NOTICE
This message occurs when Data ONTAP® detects that a storage pool has become unhealthy.
Corrective Action
(None).
Syslog Message
Storage pool %s is unhealthy. Reason: %s
reason (STRING): Reason for the storage pool being unhealthy.
raid.sp.unlock.failed
Severity
ALERT
This message occurs when the storage pool cannot be unlocked after the storage pool operation has finished.
Corrective Action
Contact NetApp technical support.
Syslog Message
Failed to unlock the storage pool %s. Reason: %s
