ONTAP EMS reference
reg.options events
reg.options.cf.change
Severity
NOTICE
This message occurs when an option is changed on one cluster node but applies to both the local and partner when the cluster is in takeover mode. The result is that the partner's setting will be overridden during takeover.
Corrective Action
(None).
Syslog Message
Option %s changed on one cluster node.
name (STRING): Name of the option
reg.options.cf.mismatch
Severity
ERROR
This message occurs during takeover processing when Data ONTAP(tm) discovers that a mismatch exists between the value of an option on the local node and an option on the partner node.
Corrective Action
(None).
Syslog Message
Option %s is not the same as on the partner node
reg.options.nullCookie
Severity
ERROR
This message occurs when an internal error occurs during the processing of the options portion of the registry.
Corrective Action
Contact NetApp technical support.
Syslog Message
registry: Unable to find the option in skiplist datastructure, but the option code is present in ONTAP. Error is %s.
error (STRING): Internal error code.
reg.options.overrideRc
Severity
ERROR
This message occurs when Data ONTAP(tm) (or an administrator) sets an option to be a value different than the value in /etc/rc. At the next reboot, the line in /etc/rc will override this setting and a reg.options.overrideRegistry message will be sent.
Corrective Action
If you want the new option to be persistent, check the /etc/rc file for this key and remove it.
Syslog Message
Setting option %s to '%s' conflicts with /etc/rc that sets it to '%s'.
newValue (STRING): New value for the option
oldValue (STRING): Existing value in /etc/rc
