sas.device events
sas.device EMS events occur when ONTAP encounters issues associated with SAS device headers and World-Wide Names.
sas.device.bad.vmdisk.header
- Severity
ERROR
- Description
This message occurs when a disk's vmdisk header is bad. The disk is unusable by the system.
- Corrective Action
Remove the disk from the system and either write a new vmdisk header to the disk or zero the disk.
- Syslog Message
SAS adapter %s reports the device at port identifier %d has an invalid vmdisk header: %s.
- Parameters
adapterName (STRING): Name of the associated SAS host bus adapter.
devicePortId (INT): Identifier of the SAS port device.
errorString (STRING): Identifies what is wrong with the vmdisk header.
sas.device.invalid.wwn
- Severity
ERROR
- Description
The SAS device responded with an invalid World-Wide Name.
- Corrective Action
Power-cycling the device may allow it to recover from this problem.
- Syslog Message
SAS adapter %s reports the device at port identifier 0x%x has an invalid World-Wide Name.
- Parameters
adapterName (STRING): The name of the associated SAS host bus adapter.
devicePortId (INTHEX): The SAS port identifier of the device.
sas.device.timeout
- Severity
ERROR
- Description
All outstanding commands to the specified device have not completed within the allotted time. As part of the standard error handling sequence managed by the Data ONTAP SAS driver, all commands to the device will be aborted and reissued.
- Corrective Action
Device level timeouts are a common indication of a SAS link stability problem. In some cases the link is operating normally and the specified device is having trouble processing I/O requests in a timely manner. In such cases the specified device should be evaluated for possible replacement. Quite often the problem results from the partial failure of a component involved in the SAS transport. Common things to check include complete seating of drive carriers in enclosure bays, properly secured cable connections, IOM seating, and crimped or otherwise damaged cables.
- Syslog Message
Adapter %s encountered a device timeout on %s device %s.
- Parameters
deviceType (STRING): The device type.
deviceName (STRING): The name of the SAS device.
