ONTAP EMS reference
scsiblade.lif events
scsiblade.lif.init.fail
Severity
ERROR
This message occurs when the SAN LIF fails to be configured during Vserver initialization. The affected SAN LIF cannot serve data until the issue is resolved.
Corrective Action
Delete and re-create the network interface by using the "network interface delete -vserver [vserver] -lif [lif-name]" command, and then the "network interface create -vserver [vserver] -lif [lif-name]" command. You can find the configuration information required to create the network interface (data-protocol, home-node, port, etc.) by using the "network interface show -vserver [vserver] -lif [lif-name]" command. If the problem persists, contact NetApp technical support for further assistance.
Syslog Message
Vserver %s network interface %s type %s could not be initialized (error %u:%u).
vserver (STRING): Name of the Vserver.
lif (STRING): Name of the network interface (LIF).
liftype (STRING): Type of network interface (LIF).
errortype (INT): Error type.
error (INT): Error.
scsiblade.lif.init.timeout
Severity
NOTICE
This message occurs when Vserver initialization finishes, and some volumes are partially initialized. This can happen when nodes are out of quorum. When the initialization timer expires, LIFs in the Vserver are brought online regardless of whether volume initialization is complete.
Corrective Action
(None).
Syslog Message
Delayed LIF initialization timer expired for Vserver "%s".
