se.changelog events
se.changelog EMS events occur when Single Instance Storage (SIS) change logging metafile is full during migration workflow through Snapmirror.
se.changelog.full
- Severity
NOTICE
- Description
This message occurs when Single Instance Storage (SIS) change logging metafile is full during migration workflow through Snapmirror. SIS will be disabled and file will be truncated to recover space.
- Corrective Action
Upon replication break, sis will enable. If there is significant loss of savings, then Run "volume efficiency start" command with "-scan-old-data".
- Syslog Message
Changelog metafile for volume %s%s%s is full.
- Parameters
host (STRING): Owning host of the volume.
vol (STRING): Name of the volume.
volident (STRING): Uniquely identifies the volume when the volume name itself is insufficient.
