ONTAP EMS reference
smtape.bkp events
smtape.bkp.abort.write.err
Severity
ERROR
This message occurs when an SMTape backup operation is aborted because a write to tape device fails.
Corrective Action
Make sure that the tape device does not have media errors and is writable. Check for error details in the log file at /mroot/etc/log/backup.
Syslog Message
SMTape backup session %d from %s to %s was aborted because write to output failed.
sessionid (INT): Session ID of the SMTape operation.
srcvolpath (STRING): SMTape source volume.
tapepath (STRING): Current destination device to which backup was performed.
smtape.bkp.fail
Severity
ERROR
This message occurs when an SMTape backup operation to tape fails.
Corrective Action
Check for error details in the log file at /mroot/etc/log/backup. Retry the command after resolving the error reported.
Syslog Message
SMTape backup session %d from %s to %s failed with error %s.
errorstring (STRING): Error string returned by SMTape.
smtape.bkp.success
Severity
NOTICE
This message occurs when an SMTape backup operation to tape succeeds.
Corrective Action
(None).
Syslog Message
SMTape backup session %d from %s to tape was successful. %s, %d tape(s) written.
stats (STRING): Statistics for the SMTape backup.
numtapes (INT): Number of tapes used.
smtape.bkp.tape.busy
Severity
ERROR
This message occurs when an SMTape backup to tape fails because the tape device is busy.
Corrective Action
Make sure that the tape device is not being used by another application and retry the operation when it is free. Otherwise, issue the command using a tape device that is not currently in use.
Syslog Message
Tape device is busy, aborting SMTape backup session %d from %s to %s.
tapepath (STRING): SMTape destination tape device.
smtape.bkp.tape.change
Severity
NOTICE
This message occurs when a CLI-based SMTape backup operation to tape reaches end of tape.
Corrective Action
Load the next tape media onto a drive and position it correctly, and then issue the 'system smtape continue -session-id [session-id] -tape [tapepath]' command with the new tape path.
Syslog Message
SMTape backup session %d from %s to %s is waiting for a tape change.
tapepath (STRING): Current destination tape device to which backup was performed.
