ONTAP EMS reference
snaplock.raidlbl events
snaplock.raidlbl EMS events occur when the periodic SnapLock disk protection check fails to validate the RAID label on disks.
snaplock.raidlbl.update.fail
Severity
ALERT
This message occurs when the periodic SnapLock disk protection check fails to validate the RAID label on disks.
Corrective Action
Run the "snaplock disk raidlabel check" command in the diagnostic privilege mode to manually trigger the SnapLock disk label check job.
Syslog Message
SnapLock disk label check fails to update RAID label. Reason: %s
reason (STRING): Reason for the RAID label update failure.
