ONTAP EMS reference
snapmirror.copy events
snapmirror.copy EMS events occur when ONTAP encounters issues associated with SnapMirror® copy operations.
snapmirror.copy.baseLine.done
Severity
INFORMATIONAL
This message occurs when the baseline transfer of a SnapMirror® copy for a volume is completed and the volume comes online.
Corrective Action
(None).
Syslog Message
Baseline transfer for volume %s completed.
dstpath (STRING): Destination volume.
snapmirror.copy.completed
Severity
INFORMATIONAL
This message occurs when the final update of a SnapMirror® copy for a volume is successfully completed and the volume is ready for transition.
Corrective Action
(None).
Syslog Message
Volume %s is now ready for transition.
snapmirror.copy.FailedErr
Severity
ERROR
This message occurs when a SnapMirror® copy relation gets an error notitication from the SnapMirror engine.
Corrective Action
(None).
Syslog Message
SnapMirror copy for volume %s failed. Reason for failure: %s.
reason (STRING): Reason of failure.
snapmirror.copy.pause.srcNoNewData
Severity
INFORMATIONAL
This message occurs when the source volume of a SnapMirror® copy relation is typed 'replica read only' and has no new data to transfer. Transfer to its destiantion is paused.
Corrective Action
If new data has been populated on the source volume by a SnapMirror schedule or manual update, run the 'snapmirror copy resume' command to restart the paused transfer. If no new data is expected on source volume,run the 'snapmirror copy complete'command to complete the volume transition.
Syslog Message
The source contains no new data; transfer to destination %s is paused.
snapmirror.copy.readyFinal
Severity
INFORMATIONAL
This message occurs when the update time taken by the latest transfer is smaller than the delta time. The volume is now ready for final update.
Corrective Action
(None).
Syslog Message
Destination volume %s is ready for final update.
