snapmirror.status events
snapmirror.status EMS events occur when ONTAP encounters issues associated with SnapMirror® replication status.
snapmirror.status.dstUpdateSnapErr
- Severity
ERROR
- Description
This event is generated when ONTAP cannot update the latest base snapshot for the replication destination. Insufficient disk space on the root volume is the most common reason for this failure.
- Corrective Action
Check if the root volume is out of disk space.
- Syslog Message
ONTAP could not update the registry with latest snapshot for the destination %s.
- Parameters
dstPath (STRING): The destination path
snapmirror.status.illegalSrcPath
- Severity
ERROR
- Description
This message occurs on a replication source appliance, when ONTAP encounters invalid source path specification while collecting replication statistics.
- Corrective Action
Check snapmirror.conf file for any typing mistakes. Typically path names are specified as "filer:volume" or "filer:/vol/volume/qtree". Check snapmirror.conf man page for discussion of path specifications.
- Syslog Message
Illegal source path: %s.
- Parameters
srcPath (STRING): The Source path.
snapmirror.status.noBaseSnapshot
- Severity
ERROR
- Description
This message occurs on replication destination appliance when ONTAP can not find the base snapshot used by a replication relation. ONTAP may run into this situation while updating replication statistics at the end of a successful transfer.
- Corrective Action
This is most likely a temporary error. Please try the operation again. Check status of the destination volume.
- Syslog Message
Can not find base snapshot for %s.
- Parameters
dstPath (STRING): The destination path.
snapmirror.status.updateStatusErr
- Severity
ERROR
- Description
This event is generated when ONTAP cannot update the ONTAP system registry with upgraded snapmirror status information. Insufficient disk space on the root volume is the most common reason for this failure.
- Corrective Action
Check if the root volume is out of disk space by issuing the 'df' command from the appliance CLI. If the root volume is full, either free up space or add more disks on the volume.
- Syslog Message
ONTAP could not update the ONTAP system registry with upgraded snapmirror status keys.
- Parameters
(None).
