ONTAP EMS reference
tcpip.conn events
tcpip.conn.leaked
Severity
INFORMATIONAL
This message occurs when a connection is leaked because it can't be closed.
Corrective Action
Many leaked connections could lead to degraded system performance. A power cycle will fix this.
Syslog Message
Connection %u to remote IP %s on vif %u using service %u over %s leaked because it could not be closed.
CID (INT): Connection ID that was leaked.
remoteIPAddr (STRING): The remote IP to which the leaked connection was connected.
VIF (INT): The VIF on which this connection was located.
serviceType (INT): The service being used on the leaked connection.
protocol (STRING): The protocol being used on the leaked connection.
