vifmgr.portspeed events
vifmgr.portspeed.err
- Severity
ERROR
- Description
This message occurs when a port is connected to a switch utilizing a link speed that is not qualified. This might lead to unexpected system behaviors.
- Corrective Action
Ensure that the affected network port is connected to a switch that uses a link speed supported by this node. If necessary, adjust the switch configuration to assign a lower speed.
- Syslog Message
Node %s port %s is reporting a speed %s that is not supported.
- Parameters
nodename (STRING): Name of the node on which the affected port resides.
portname (STRING): Name of the affected port.
portspeed (STRING): Operational speed of the affected port.
