ONTAP EMS reference
vsdr.periodic events
vsdr.periodic.check.errors
Severity
ERROR
This message occurs when the Vserver DR subsystem periodic check detects issues with the Vserver DR components. These issues could potentially result in a degraded Vserver DR relationship. So, some corrective action is required by the admin to resolve the issue.
Corrective Action
Contact NetApp technical support to identify and resolve the issues with Vserver DR components.
Syslog Message
Vserver DR check between source Vserver %s and destination Vserver %s found issues with the attribute %s.
source_vserver (STRING): Name of the source Vserver of the Vserver DR relationship.
destination_vserver (STRING): Name of the destination Vserver of the Vserver DR relationship.
attribute (STRING): Name of the attribute that is being checked.
vsdr.periodic.msid.preserve
Severity
ALERT
Vserver DR subsystem has detected that volume MSIDs are not preserved. This would require remounting NFS clients after a DR fail-over. Such relationships may not be supported in future ONTAP releases. Convert the relationship into an MSID preserving relationship. As part of conversion, the DR Vserver will be stopped and the volume MSIDs will be re-stamped.
Corrective Action
See the KB article https://kb.netapp.com/support/s/article/How-to-convert-DR-Relationship-into-MSID-preserving-relation for more information on how to convert the relationship into an MSID preserving one.
Syslog Message
Vserver DR: Possibly deprecated variant of Vserver DR relationship for the destination Vserver %s.
