ONTAP EMS reference
vserver.dest events
vserver.dest EMS events occur after you have modified either the size or maximum autosize of a source volume in a SnapMirror sync relationship and the maximum autosize at the destination DP volume (which is in a storage limit enabled SVM) fails to modify automatically.
vserver.dest.volume.modify.failed
Severity
ERROR
This message occurs after you have modified either the size or maximum autosize of a source volume in a SnapMirror sync relationship and the maximum autosize at the destination DP volume (which is in a storage limit enabled SVM) fails to modify automatically. The failure occurs because the destination cluster is unreachable.
Corrective Action
Verify network connectivity between the local cluster and the peer cluster. Check the cluster peer EMS messages for more information.
Syslog Message
Maximum-autosize of destination volume "%s" which is in a storage-limit enabled SVM "%s" was not modified.
vserver_name (STRING): Name of the storage virtual machine (SVM).
volume_name (STRING): Name of the volume.
