ONTAP EMS reference
wafl.buf events
wafl.buf EMS events occur when ONTAP encounters issues associated with file system buffer inconsistencies or corruption.
wafl.buf.badHeader
Severity
EMERGENCY
This message occurs when the system encounters a bad header in the snapshot of the active map block of the filesystem.
Corrective Action
Delete the bad snapshot. For a SnapMirror® target, rebuild from source or resynchronize, after deleting the snapshot. If the problem persists or if you need further assistance, contact NetApp technical support.
Syslog Message
Bad header in snapshot of active map in %s %s%s%s%s, snapshot %d, fbn %llu.
type (STRING): Type of object (volume or aggregate).
owner (STRING): Owner of the volume.
vol (STRING): Name of the volume.
app (STRING): Application UUID.
volident (STRING): To uniquely identify the volume in cases where the volume name itself is insufficient.
snapId (INT): Snapshot identifier.
fbn (LONGINT): File block number.
wafl.buf.freeingFreeBlock
Severity
EMERGENCY
This message occurs when the system encounters a "freeing free block" error due to file system corruption.
Corrective Action
(Call support).
Syslog Message
Freeing free block at VBN %llu in %s %s%s%s%s. WAFL inconsistent. Contact NetApp technical support.
vbn (LONGINT): Virtual block number of the block that is freed.
voltype (STRING): Type of the volume.
volowner (STRING): Owner of the volume.
volname (STRING): Name of the volume (again). This is returned from WAFL_VOL_PRINT_NAME_STRINGS.
volident (STRING): Uniquely identifies the volume in cases where the volume name itself is insufficient.
vendor (STRING): Name of the vendor.
