ONTAP EMS reference
wafl.mount events
wafl.mount.fa.incons
Severity
ERROR
This message occurs when the flexaggregate cannot be mounted; the flexaggregate is marked as inconsistent.
Corrective Action
Contact NetApp technical support.
Syslog Message
wafliron could not mount flexaggregate %s due to %s. Flexaggregate is marked as inconsistent.
flexaggrname (STRING): Flexaggregate name.
reason (STRING): Reason for the failure.
wafl.mount.inconsistent
Severity
ERROR
This message occurs when the FlexVol® volume cannot be mounted; the volume is marked as inconsistent.
Corrective Action
Unable to mount the volume. Run wafliron to diagnose the volume.
Syslog Message
WAFL: Unable to mount volume %s due to %s. Volume is marked as inconsistent.
vvolname (STRING): Volume name.
reason (STRING): Reason for the inability to mount the volume.
wafl.mount.info
Severity
NOTICE
mount message
Corrective Action
(None).
Syslog Message
%s
msg (STRING): Message from wafl vol mount path which prints how many messages were sent to WAFL.
wafl.mount.transient.error
Severity
ERROR
This message occurs when a FlexVol® volume cannot be mounted due to transient errors and the volume is taken offline.
Corrective Action
Firstly, attempt to bring the volume online manually by using the "volume online" command. If the issue persists, determine whether the volume is a NetApp® Aggregate Encryption (NAE) volume by using the "volume show -encryption-type aggregate" command. If so, remount the aggregate of the volume by taking it offline (using the "aggr offline" command), and then bringing it online again (using the "aggr online" command). If the issue still persists, contact NetApp technical support. For ASA r2, contact NetApp technical support for assistance to resolve this internal error.
Syslog Message
WAFL: Unable to mount volume %s, UUID %s due to %s. Volume is taken offline due to transient errors.
uuid (STRING): Universal unique identifier (UUID) of the volume.
reason (STRING): Reason for the failure to mount the volume.
