ONTAP EMS reference
xfcvi.unsupported events
xfcvi.unsupported.config
Severity
ERROR
This message occurs when a network adapter port behavior type is set to use FC-VI on a platform that has not been validated for its use and is therefore unsupported.
Corrective Action
Change the port behavior type to a value other than "FC-VI". Use the "system hardware unified-connect show" command to view network adaptor port information, including the current behavior type. Use the "system hardware unified-connect modify" command to change the network adapter port behavior type.
Syslog Message
FC-VI port behavior type not supported on network adapter port %s.
port (STRING): The network adapter port whose behavior type is set to use FC-VI.
