aggrcopy.dst events
aggrcopy.dst EMS events occur when ONTAP encounters issues associated with aggregate copy operations on the destination aggregate.
aggrcopy.dst.autoRestrictMsg
- Severity
NOTICE
- Description
This event is issued when an aggregate copy start is issued on an aggregate which is offline.
- Corrective Action
Aggr copy start is issued on a restricted aggregate use "aggr restrict" to restrict the destination aggregate.
- Syslog Message
Aggr copy automatically restricting destination aggregate %s (currently offline).
- Parameters
dst (STRING): The aggr copy destination aggregate
aggrcopy.dst.noMemory
- Severity
ERROR
- Description
This event is issued when there is insufficient memory on the aggr copy destination for the transfer to continue.
- Corrective Action
(None).
- Syslog Message
System is low on memory, aborting aggr copy destination transfer.
- Parameters
(None).
aggrcopy.dst.revert
- Severity
NOTICE
- Description
This event is issued when an aggr copy start operation has to revert the checksum state of the destination volume aggregate because the source and destination aggregates have differing checksum states.
- Corrective Action
No corrective action required.
- Syslog Message
An aggr copy transfer to destination aggregate %s has found that the source and destination aggregates have differing checksum states. Data ONTAP is aborting the transfer and reverting the checksum state for the destination aggregate. After ONTAP displays a message showing the revert is complete, you will need to retry the operation. You can use the "aggr status -c" command to see the progress of the reversion.
- Parameters
dst (STRING): The aggr copy destination volume
aggrcopy.dst.revertErr
- Severity
NOTICE
- Description
This event is issued when a aggr copy start operation is not able to revert the checksum state of the destination aggregate.
- Corrective Action
(None).
- Syslog Message
ONTAP cannot revert the checksum state of destination aggregate %s.
- Parameters
aggrcopy.dst.reverting
- Severity
NOTICE
- Description
This event is issued when an aggr copy start operation is issued on an aggregate which is reverting its checksum state.
- Corrective Action
(None).
- Syslog Message
Aborting aggr copy transfer to aggregate %s because it is reverting its checksum state.
- Parameters
