ata.timeout events
ata.timeout EMS events occur when ONTAP encounters issues associated with I/O requests to the ATA driver timing out.
ata.timeout.failed
- Deprecated
Last used 9.2
- Severity
NOTICE
- Description
This message occurs when an I/O request to the ATA driver times out. This might be indicative of an overloaded back-end storage subsystem. The retries for this I/O operation have been exhausted; the I/O operation has failed and will not be retried.
- Corrective Action
(None).
- Syslog Message
ATA device timeout (%s).
- Parameters
ata_timeout (STRING): Timeout message from the ATA driver.
ata.timeout.retry
- Deprecated
This event is no longer used because of misleading text. See new EMS of EMS_cam_timeout_retry. Last used 9.7.
- Severity
NOTICE
- Description
This message occurs when an I/O request to the ATA driver times out. This might be indicative of an overloaded back-end storage subsystem. The I/O operation will be retried; this message does not indicate failure.
- Corrective Action
(None).
- Syslog Message
- Parameters
