ONTAP EMS reference
azurearc.new events
azurearc.new EMS events occur when a new Microsoft Azure Connected Machine Agent has been onboarded to Azure Arc.
azurearc.new.agent.created
Severity
NOTICE
This message occurs when a new Microsoft Azure Connected Machine Agent has been onboarded to Azure Arc. A new Microsoft Azure Connected Machine Agent may be onboarded, for instance, when the original ONTAP cluster management server, also called an administrative SVM fails and a new node is designated as the cluster management server. This message is only applicable to Azure NetApp Files systems.
Corrective Action
(None).
Syslog Message
A new Microsoft Connected Machine Agent has been onboarded to Azure Arc. Node: %s
node (STRING): Node name of the cluster management server where the new Microsoft Connected Machine Agent was onboarded.
