ONTAP EMS reference
bdfu.selected events
bdfu.selected EMS events occur when background disk firmware update selects a disk for firmware download.
bdfu.selected
Severity
INFORMATIONAL
This message occurs when background disk firmware update selects a disk for firmware download. The disk contents will be copied to a suitable spare, the disk will be removed from the raid group and then firmware will be downloaded to it. After the firmware download is complete, the contents of the disk will be restored.
Corrective Action
(None).
Syslog Message
Disk %s [%s %s %s] S/N [%s] selected for background disk firmware update.
diskName (STRING): Name of the disk.
vendorName (STRING): Vendor name of the disk.
productId (STRING): Product ID of the disk.
fwVersion (STRING): Firmware version of the disk.
serialno (STRING): Serial number of the disk.
